Hey guys, I need an instant set wood glue,
    • 27460
    would lock tight in the bottle be a good option, or some other suggestion. I broke two legs off this table that means a great deal to me. There is a lot of wood to glue, so that is the good news. It's a small table, so not a huge amount of stress. I tripped and fell and broke them. I broke one before just walking into the leg, table is in the way. I fixed it, but I do not believe this is the one that broke. It's an old antique table that belonged to my Mom, the legs stick out, and well, I don't have a lot of room for it, so it's going to be in the way probably always.
    The wood is oak I believe.
    But I want to get it fixed tomorrow.
    • 2142
    Hey Doug,
    About the only thing that will give you instant gratification is CA glue, i.e., super glue. I would not go that route for a permanent fix though. Why does it have to be instant?
      • 1044
      Depending upon the nature of the break, clamps and bracing/strapping seem like a starting point, not an end point. And you want some open time for that.
        • 1577
        Hey Doug,
        About the only thing that will give you instant gratification is CA glue, i.e., super glue. I would go that route for a permanent fix though. Why does it have to be instant?
        Point of order - I believe Steve meant he ~wouldn't~ use that as a permanent fix?
        My grandfather would occasionally use Titebond 1 or 2 (I think 2) and just press a piece together by hand for a couple minutes before letting go and calling it good - no stress for a day of course. I'm not really recommending doing that, but unless you have clamps the choices are kind of limited.
          • 2142
          Thanks for catching that Danny .... just fixed it. Yep, Titebond I II or III and clamps ought to do the trick.
            • 27460
            Thanks guys, I accidentally kicked a leg once before and it broke, they are pretty wirey bendy, and have a couple of thinner places. Well, my house is such a disaster zone, I got up from dinner and tripped and slammed down on the table and broke two legs. I did try super glue and gaffer tape to hold in place,2 different kinds as a matter of fact, and it did not setup. The wood is a little wormy looking inside, probably one reason is so weak.
            I wound up using some Titebond and taking my time, gluing 1 leg at a time and let dry overnight. I used gaffer tape as my clamps, plus they had one rusty nail from the top to help hold. One came out really nice, the other is not perfect, but they are so low, you can't hardly see them. So, for now, it is mended ok. Oh, all the crooks and bends make it really difficult to clamp.
            Thanks for the input! I will shoot a photo of them some day and you will see what I mean!
            Happy holidays to our DIYers!
              • 1577
              I'm glad you got it sorted Doug, definitely post a picture sometime!
                • 27460
                Yes, already got special cards and photos in the only small drawer. Photos on top, so I am happy, photo still yet to come, I been working real hard here since Friday. First one project then another! Mostly moving stuff around, and preping for some haul out of here.
                Here is a placeholder photo, lol.
                I have perfected my bacon cooking skills since this was cooked. I cooked it to high, and fast. I found that a 5.5 on my range on non stick good cookware makes it perfect, if you flip it, flip it again about 2 times during cooking, I go by looks when it's done, not really time, though I would like to time it, the last I cooked had to unthaw while cooking, it worked out ok though, perfect strips, golden brown, no black.
                  • 1577
                  Well I dunno about anyone else, but now I'm hungry!
                  • 1Michael
                    • 295
                    That's just cruel...
                    Michael
                    Chesapeake Va.
                    • Amphiprion
                      Anything to dissolve yellow wood glue?
                      by Amphiprion
                      I have a table saw on long-term loan from a friend while he is working out of state. It's basically table-top unit with an added stand, all-aluminum table top, direct drive affair. He hasn't been too careful with it and it looks like he's glued up a fair number of projects using it as a table - lots...
                      13 June 2006, 14:48 Tuesday
                    • JonW
                      Making Speaker Cabinets: MDF, Plywood, or Wood?
                      by JonW
                      I’m planning on building my first set of speakers soon. The Modula MT’s, most likely. Many other questions will follow, but here’s a general one: What should I make the cabinets out of? I’ve read a lot (web and books) and see that MDF is preferred. Plywood seems to be coming in second....
                      25 February 2006, 12:51 Saturday
                      Note on Wood Glue and Gorllia Glue
                      by ---k---
                      Because the subject of glue comes up often around here, I wanted to mention to everyone that this months Fine Woodworking Magazine did a test of several of our favorite glues. The results were somewhat surprising (or not), and exposed something that is commonly repeated to be false.
                      08 June 2007, 13:48 Friday
                    • jquin
                      Repair RS225, which glue?
                      by jquin
                      Hi all
                      It's been a while. I should get around to posting a picture of my M8ta.
                      Anyhow I one of my RS225s broke recently. The aluminium cone can loose from the (what I'm going to call) voicecoil. It seems that there are a combination of interference fit and glue.
                      Does anyone know...
                      15 April 2012, 18:21 Sunday
                    • silvia0073
                      Absolute Noob at wood working and am building Jim's Statement IIs
                      by silvia0073
                      Ok, I've been a long time browser of htguide, just never registered. You guys are an absolute treasure trove of knowledge! I've recently taken the plunge into diy and to start out, as a first ever project, built Jim's TriTrix speakers with the parts express kit. Kit being CNC'd, all the cuts were...
                      02 February 2016, 14:29 Tuesday
