Hey,
I am planning another speaker build for summer. I built the sealed CJD RS150 MTMs (with Seas H1212 tweeters) a couple years ago, and love them. I began doing freelance recording and mixing a year ago and have been using these as my main monitors with great results. I use 4 IB15s to cover the low end.
So my main goal is to build a couple full-range (down to 30 Hz would be great, anything lower just a bonus) speakers to use as another pair of monitors, possibly taking the place of my RS 150MTMs as my primaries and moving those to my secondaries.
My current room is 13'x10'x8' ceilings with a decent amount of room treatment (16 2'x4'x2" fiberglass and rockwool panels used as bass traps and broadband absorbers). No diffusion as of now since the room is fairly small. My room is on the dead side, but it works out great for mixing. The accuracy in both soundstage and frequency response compared to before room treatment is just mind-blowing.
My current speakers are about 15" off of the front wall, so that shouldn't be too much of a problem with the Mini Statements, if I understand correctly. I can nudge another 3" if necessary.
I am sort of doing this for fun, since I finally got a full time job and can save up for it by summer. But I am also looking for something that is very accurate, voiced differently from my current speakers, and will be something that I can use for mixing, and in the future for mastering.
My budget is about $700 for the pair, but I am a bit flexible since I am planning a few months out.
So for those of you who have built the Mini Statements, do you think they will serve my purpose? Anything else out there that I am overlooking, or anything else I need to mention?
Thanks in advance!
Thanks in advance!
