Update to NatalieP?
    The TL Be dome in Europe costs the same as the Be domes from SEAS and Scan.
    Don't forget that the SS9900 and SS9700 are essentially the same tweeter but with different face plates. One of the advantages of the older scan tweeters is they have lower 2nd order products. Their 3rd order isn't quite as low as the newer stuff though. I've had my eye on the 71000 for a while, it seems like it performs just marginally better than the 6600 and I like it's sculpted rear chamber too, even if it's only really cosmetic.
    • Jonasz
      • 854
      That is what I thought too but according to Jeff...
      The 9700 has the same dome assembly and voice coil as the 9500, but it has the same motor shorting rings and cap as the 9900. It does not have ferrofluid. It has a smaller chamber, different pole-piece damping, and a different faceplate than the 9900. The 9900 differs from the 9700 in these ways as well as having a different dome too. The only thing the 9700 and 9900 share are the same SD-2 motor design and voice coil. The impedance curves are very similar, but the 9900 has a little higher midband sensitivity.
      I haven't used my 9900s for about 20 years or so but they were always my reference back in the days. I always assumed technology had moved on so they've been laying on the shelf ever since but now I think I'm going to wipe the dust off and let them sing again! Got a couple nice 6,5" I'm going to pair them up with. 8)
      I think the 9900 were a little ahead if it's time with the wg wich wasn't really fashionable at the time, maybe that's why they never got the same popularity as the 9700, well that and the size and price...
        • 16128
        There any way to find out if it's really pure beryllium?
          • 16128
          Looks like the ES140Ti is back in stock Jon.
            Hmm as far as I know the dome/coil assembly for the 99 and 97 are the same. You can buy replacements from Madisound and the 93/95 share a part as do the 97/99. I thought the main difference was that the 93/95 had perforations in the former to allow the ferro to flow better, and the 97/99 obviously did not.
            • Jonasz
              • 854
              I just checked because I was of the same opinion as you but they really are different. Apparantly 93/95/97 share the same dome and vc, unless there are typos over at Madisound.
              Replacement Voice Coil for Scan-Speak D2905/9900 tweeter (290032)General Instructions for Repair:1. Remove the four small Torx screws (T8 bit) that hold the tweeter faceplate to the magnet assembly. Set aside.2. Remove the plastic ring. Set aside.3. Carefully remove the foam gasket. Set aside.4. Clip voice coil lead wires from solder tabs.5. Remove solder tabs. Discard.6. Remove voice coil assembly from magnet assembly. You may have to pry it out. Discard.7. Remove tape on new voice coil assembly.8. Fully insert new voice coil assembly into magnet assembly. Make sure to line up the voice coil lead wires with solder tab location.9. Insert new solder tabs.10. Solder voice coil lead wires to solder tabs.11. Replace foam gasket.12. Replace plastic ring.13. Replace face plate.14. Slowly tighten four Torx screws.
              Replacement Voice Coil for Scan-speak tweeters D2905/9300  D2905/9500  D2905/9700 General Instructions for Repair:1. Remove the four small Torx screws (T8 bit) that hold the tweeter faceplate to the magnet assembly. Set aside.2. Remove the plastic ring. Set aside.3. Carefully remove the foam gasket. Set aside.4. Clip voice coil lead wires from solder tabs.5. Remove solder tabs. Discard.6. Remove voice coil assembly from magnet assembly. You may have to pry it out. Discard.7. Remove tape on new voice coil assembly.8. Fully insert new voice coil assembly into magnet assembly. Make sure to line up the voice coil lead wires with solder tab location.9. Insert new solder tabs.10. Solder voice coil lead wires to solder tabs.11. Replace foam gasket.12. Replace plastic ring.13. Replace face plate.14. Slowly tighten four Torx screws.
              Maybe the SS9800 could be another contender, best aluminium dome available rivalling the SS Berylliums in performance according to Troels.
                Interesting that's changed since I last looked, or perhaps I am remembering another website. Here I found it.
                Self-assembly loudspeakers Filter components, building kits. Made-to-measure in Speaker construction. RumoH since 2006. Loudspeaker Repair, cabinet…
                They sell the same part for both and then something different for the 93/95.
                I guess we will never know. I did try and buy a replacement for the 97 from wilmslow audio a long time ago, I still haven't repaired that tweeter, but whatever it was they shipped to me wasn't the same as what was in the tweeter and it wouldn't align properly in the gap either. Needless to say I sent it back.
                The good old russian chap has done a recent measurement of the 99 too. So now he's done with the 99 and 97. They are very similar in distortion performance and both perform very well. The 99 is ever so slightly better though.
                It is a fantastic tweeter.
                  • 16142
                  It's the ES180ti that's been out- I will order some more ES140ti shortly- after back from this next trip!
                    • 16128
                    Oh well a week ago or so the 140 was out as well.
                      • 16142
                      thanks for the links- checked that out. Guess the only thing to do is buy a pair and test them, too!
                        • 16142
                        Originally posted by Face
                        Doesn't sound right to me either.
                        You can get them from Solen for $300 each. Considering what their ceramic dome units sold for, and that others have bought them direct from TL at that price, I guess it's real. Something else to put on the purchase and test list.... maybe first!
                          • 16128
                          Yea that's a steal for a BE tweeter.
                            Haha, thumbs up for the good old revelator. It's funny really the design is pretty old and for all of scan-speaks new tweeters, it still manages to hold its own, most notably is the fact that 2nd order is much lower than their newer offerings.
                              • 16128
                              Are the older revelator tweeters cheaper now?
                                • 16142
                                It's 5:20 in the morning, I'm at a nearby Starbucks to home, I've got a full tank of gas, and it's 866 miles to Burlington WA. No cop tires, no cop suspension, just a Honda Element in good shape with a 5' X 9' motorcycle trailer behind me, and a lot of miles to go in front of me. Should be there Friday afternoon.... where that RADD suspension Yamaha GTS1000 is waiting for me.
                                Road Trip! :B
                                I think my GF thinks this is the craziest thing I've done since I met her... OTOH, that big shipment of LBL for the new speaker project arrived while we were down in Santa Barbara, so we may be running neck and neck on these two events.... :W
                                  • 16142
                                  Well, you guys have convinced me for now- I'm ordering a pair of these to check out. But I'll probably also order a pair of the Be TL tweeters. And at this rate, there will have to be three versions of the NatalieP ES, all with different tweeters- choose your preference! Maybe 4, if the ceramic TL N26 requires different optimizations than the Be N26.
                                  I had a weird dream last week, too- an outlandish system, a 2.5 way with the 5.5's and four of the ES180's in each cabinet for the 0.5 way part. Yes, that's 2-5.5" and 4 7" in each cabinet. Must have been something I ate... :B
                                    • 16128
                                    Doesn't sound that crazy, my Dynamic 4t's aren't far off with the 4 RS180's and 2 tangband 4" mids lol. Although 4 ES180's gets pricey!
                                      If Jon ever has a garage sale, it might be worth driving a Uhaul from Chicago to Livermore and back for.
                                        • 16128
                                        You got that right!
                                        • dwk
                                          NHT Xds desktop/nearfield system
                                          by dwk
                                          No pictures yet, but thought there might be a bit of interest in something slightly different. My projects tend to move at the pace of glacial creep albeit without the sense of inevitable certainty, so when I hit a milestone it merits a bit of celebration.
                                          My particular DIY 'itch'/interest...
                                          14 June 2011, 17:09 Tuesday
                                          Motus + ScanSpeak = NatalieP Ultra... Black is back
                                          by Evil Twin
                                          Possibly of interest to those looking for a high end solution at more of a midrange price (of course, everything is relative, including those adjectives...)
                                          Components are in the lab and testing under way, after careful selection...
                                          Motus UH165PW1 - the...
                                          03 May 2016, 15:30 Tuesday
                                          NatalieP DA- revisiting a popular design with a new tweeter
                                          This started off more as a "What if?", and then progressed to a "Why not?" sort of deal... it's too bad the original RS28a tweeter went away, but we do have some alternatives these days that are interesting...
                                          So why not combine most elements of the classic design from...
                                          02 December 2021, 15:28 Thursday
                                        • Branwell
                                          Help choosing a midrange setup ( W15 or W18 Nextel drivers ) please.
                                          by Branwell
                                          I am hoping for some opinions. Some input.
                                          If you where to do a 3 way and where given a choice between two midranges setups, which would you chose and why ?.
                                          The tweeter would be a Seas Millennium, and the bass, a pair of non sub bass drivers per side...
                                          01 January 2006, 17:13 Sunday
                                        • crazyjpeters
                                          NatalieP ML-TL build
                                          by crazyjpeters
                                          Hi All,
                                          After much deliberation, I've decided to build a NatalieP (the decision to make a NatP didn't take much thought, after seeing all the praise it gets on this forum). But I wanted to do something different. I've decided to do a ML-TL, and with Paul K's advice and Martin's spreadsheets,...
                                          16 October 2009, 15:09 Friday
