Zaph ZA5.3 MTM in a Steel Tube?
    Ahh, the joys of torch work. I'm not sure straight propane would get quite hot enough for the thickness of that steel, probably need an oxygen/gas mix (probably doesn't have to be OA) but that's bucks... and fun.
    It's fun to burn off rust too.
    DO NOT do this in your garage. You need adequate ventilation.
      Originally posted by frascati
      Really interesting things can be done with steel. One that I've used occasionally is simply cleaning the metal really well and leaving it outdoors to weather for a bit until it gets a somewhat even layer of surface rust. Then apply something called RustFix by Duplicolor
      It sprays on clear and reacts with the surface oxides to create a pretty interesting surface of very hard, very black "rust".
      That sounds like a similar product to Krud Kutter http://www.krudkutter.com/mustrust.asp that I used to get me to where I'm now. I didn't realize that the "inhibitor" actually creates a layer of rust on them. It works well, but I'm looking for shiny steel look - I want people to know what they are! It takes a lot of effort to get that layer off. I'm not sure I'm going to get what I want, but these are a becoming a great learning through failure experiment.
      I like the torched look. That is pretty neat. But yeah, to heat this much steel... wow!
      I might be going in circles and doing things just to fail, but I'm having fun. It is keeping my mind off work and I haven't blown the house up. So, it meets my goals.
        I got 18' of 1/2" threaded rod, some nuts and washers - only another $38. This project is getting expensive! I drilled out a 7/8 dia recesses on the back of the front baffles, which I'll epoxy the nut into so nothing shows on the front. A drill press and Forster bit would have been really useful. It's a little sloppy, but should work. For the back, I drilled 1/2" dia through holes.
        I've cut two lengths of threaded rod with a hack saw and my arm is about to fall off. I tried a dremel, but that didn't work too well. I suppose I need a metal cutting blade for my chop saw. I think by the time I finish with these speakers, I'll have every tool they sell at Lowes - which wasn't my intention...
        And unfortunately, I have to go to a 4-year-olds birthday party.
          I'm not making much progress on this project... And I'm about to undertake building a smoker, and... so, I just put the kit up for sale in the pawn shop with some other misc parts. It would have been a cool project, but I don't have time and my Khans keep me so happy I'm not sure when I would have ever listened to these.
          So, if anyone is interested:
          • evilskillit
            • 468
            I was really looking forward to the steel speaker cabinet. I was wondering about it recently. C'est la vie. Maybe someone else will be inspired by what you started and do it themselves.
              Yeah.. me too... it was going to be a fun experiment.
              If someone in Chicago wants the steel tubes, they can have them. Otherwise, they make great weights for glue-up projects.
              • evilskillit
                • 468
                Are you by chance coming to DIY Iowa? If so I bet someone there might take them and pick up on the project where you left off. Well or any other DIY show for that matter. I ask because I'll be at Iowa.
                  I was going to go to Iowa. I even had these entered. But, then I got tickets to see JJ Grey & Mofro at House of Blues here in Chicago. Of course, it was the same night.... I choose JJ Grey.
                  I never thought I would get into "swap music", but you got to check out JJ Grey. His newest release is getting a lot of press recently: wsj, usa today, American airlines. I still like his third album best, Lochloosa.
                  JJ Grey & Mofro: Music, tour, shop, news, and more.
                  • Clint
                    WT2, WT3, MCM's Woofer Tester, or some other?
                    by Clint
                    Hi all, I came across this forum while searching for woofer testers, and more info on the one MCM sells (Tenma 72-850). I found out from here about the Dayton WT3 that PE sells for about $68 less than the Tenma, and about the WT2 at woofertester.com .
                    So the question now is, which of...
                    04 February 2008, 01:52 Monday
                  • Muskiehunter
                    Tube subwoofer Ideas
                    by Muskiehunter
                    I have a 16 inch steel pipe with 3/8 walls 22" long. Thinking of making down firing sub out of it. Any metal fab is no problem. I was planning on welding four 3/4 to 1 inch round stock legs to support it off the floor. Then welding a top out of 3/8 plate steel. Then just welding in a ring and...
                    14 March 2012, 16:09 Wednesday
                  • LING GOWA
                    Measuring caps with WT3?
                    by LING GOWA
                    How does one measure caps with WT3?
                    29 December 2009, 16:20 Tuesday
                  • impulse
                    Measuring T/S in free air with WT3
                    by impulse
                    Hi. I need some advice on how to measure TS-data of a driver. I know it should be measured in "free air" and not while laying horisontally on a table, but is it ok just to hold the driver by the magnet in free air when taking the measurement with WT3 (Dayon woofer tester 3), or should it be...
                    01 February 2010, 09:10 Monday
                  • EDS
                    Steel Speaker Enclosures
                    by EDS
                    I've been reading the forum for a couple months and have really enjoyed all the projects.
                    I work in a manufacturing company specializing in laser cutting and CNC bending. I have the resources of 3D modeling and a million dollars of equipment to produce steel parts.
                    I assume...
                    25 January 2006, 09:29 Wednesday
