Measuring caps with WT3?
  • LING GOWA
    • Dec 2007
    • 165
    How does one measure caps with WT3?
    Website
    • 15213
    One doesn't. WT3 is unreliable and flaky in my experience- as an owner. Ended up getting the real deal from Smith and Larson.
    Not to be harsh- YMMV - just look at all the posts with people getting weird results with WT3 on Tech Talk.
    • fjhuerta
      • 1140
      You mean, the WT2, Jon?
      Javier Huerta
        • 15213
        Yeah, that's what I have- from Smith and Larson. WT2. Was trying not to directly send people away from our sponsor. But maybe I can get away with it, considering all the cabinets and crossover parts I've bought from PE in the last two weeks!
        Like these! Destined for the ultra secret Modula Xtreme system!!
        • LING GOWA
          • Dec 2007
          • 165
          Ultra secret.... you can tell me....I won't tell anyone.....trust me.
          Website
            • 5202
            I'm not arguing with Jon. He is typically right. But for us those with the WT3 already or what have you, here is a post by Curt Campbell that discusses how to do it.
            To determine capacitance from the impedance sweep, a simple calculation must be accomplished.
            The formula for determining capacitance is:
            C = 1 / (2pi f Xc) –where C is in Farads and Xc is the impedance of the capacitance in ohms at a specific frequency.
            We can make this formula easier to remember by assuming a measurement frequency of 159 Hz:
            C (in microfarads) = 1000 / Xc)
            Or for 1590 Hz:
            C (in microfarads) = 100 / Xc)
            Example: An unknown value cap shows an impedance of 500 ohms at 159 Hz when an impedance sweep is done. Substituting that value for Xc in the formula we have:
            C = 1000 / 500 = 2 uF
            OK. While the above calculation can be easily done in one’s head, the more astute of you will have by now noticed that there is no vertical index line on WT3 at 159 Hz or 1590 Hz. -While you could eyeball it, as I do, or save the impedance file and then open it up in notepad to find the value, it perhaps would be easier to choose a demarcated frequency close to a normal crossover frequency, like 200 Hz or 2 kHz. A close approximation for those frequencies is:
            C = 80 / Xc for 2000 Hz
            C = 800 / Xc for 200 Hz
            -And maybe an easy one to remember for Xc measured at 1000 Hz:
            C = 159 / Xc
            For best accuracy, I’d make my measurement at a frequency where the impedance is changing value rapidly. The impedance and frequency scales of WT3 can be expanded to make the capacitance measurements quite easy and accurate.
            __________________
            Curt's Speaker Design Works
              • 15213
              Good post Ryan!
              I just wasn't in a good mood about the WT3 due to having bought two of them and both going south after not very long.
              • fjhuerta
                • 1140
                I have the WT2, too - it was the first measurement equipment I got. I have never regretted it - it's so simple to use, support by the S&L team is amazing (I got a special build of the software when I was beta testing Win 7), and it's completely dependable. Measuring the LRC parameters of just about anything is pretty simple and straightforward - plus it does so much more. Love it!
                Javier Huerta
                  • 5202
                  Good post Ryan!
                  Well, the credit should got to Curt. He is the brains; I'm just the parrot.
                  • Undefinition
                    • 577
                    Am I the only one who uses the demo mode of Praxis? I'm sure there are more turnkey solutions, but I prefer the price of this (free). It does require making your own testing probes, but I just use the ones I made for LSPCad.
                      • 15213
                      Well, I've used the paid mode of Praxis, too, but I still find CLIO to be simpler- but how many people do you know with an Athlon PC with ISA slot and a Version 6 CLIO setup?
                      Of course, I also have an HP LCR meter, but because of it's size, it's usually in my climate controlled storage! You can get some good deals on older equipment from Test Equity and other places, plus eBay, of course.
                        Even the Sears by me stocks somewhat decent LCR meters.
