Hi all, I came across this forum while searching for woofer testers, and more info on the one MCM sells (Tenma 72-850). I found out from here about the Dayton WT3 that PE sells for about $68 less than the Tenma, and about the WT2 at woofertester.com .
So the question now is, which of these gives the most accurate T/S parameters for any kind of driver?
Will the Dayton WT3 give all T/S parameters like the Q, Fs, etc? I saw someone mention here that it does not.
Is the 72-850 and the WT2 at woofertester.com the same unit?
Thanks.
Thanks.
