Class is in- that is, CLASS D in in session now!
    • 16156
    That was quick of Kevin- thank you very much for getting this up so quickly.
    Now we can move some of the topics from our emails to the forum- it also occurs to me that I can start a "White Paper" thread and discuss some of the technical topics regarding the input stage, power bypass, supply regulators, and protection systems.
    Some of this is because I want you all on board, but also it will be helpful for you to have a clear notion of the complexities involved; not to make too big a deal, but not to overlook things. There are several paths that could be taken, and even the OEM Adapter board is one possibility for a simple setup that roughly approximates an NCORE 400 DIY setup. Probably the best thing to do is to start separate threads on each key topic and functionality issue.
    Great, then we have a forum area :-)
    I agree with you that it might be a good idea to start new threads on key areas. In addition I guess we might as well start separate build threads for actual builds, but then split out if there are more general issues?
      Great, I'm in I think.8O
      I think I'm probably the least complicated just a stereo case with dual mono, 2-SMPS1200A700 & 2-NC500's. I just need Balanced connection as I would then be balanced through my whole chain and would like,
      1. Power trigger from off or standby state, on / off switch can be on the back as this will be mounted on a shelf in the rack.
      2. A power source from standby and on for a front led display. The led display can be made from a couple of addressable Neo pixel strips programmed from an Arduino UNO board and would just change color to indicate on or standby, protection if there is a state like this for Ncore. If power is only available when ON then that's fine too I just have to be able to control the LED's brightness when on.
      3. I have no need to switch OP amps what ever is chosen is fine. Jon what ever board for input you deem an improvement is fine with me.
      I have an Emotiva XPA-5 all the power I need for 5 channels of home theater.
      TEK, sure you need a 5 channels of Ncore an XPA-5 is $800. US? Great buy with your new 8801av. I have the AV7005.
        • 16156
        One thing I recommend or request is that each of you start a thread outlining your own goals and your current perception of what you need to get there...
        Darrel, it's sounding a bit like the performance of the OEM adapter board would be OK for your requirements. That could get you up and running very quickly.
        My interest is in a fairly comprehensive solution, with additional supply bypass/filtering, a lower noise front end with transformer isolation (presuming it ends up working as I expect), higher performance regulation for the signal front end (not 78xx class regulators as used on the OEM board); a separate DC detect and speaker relay for additional system protection, and stuffing options for controlling the configuration (for example, the "normal" Hypex dual op amp instrumentation front end takes so little board space, that this could be put on also, and then the board configuration (transformer and special differential amp, or standard Hypex approach) be determined by what's stuffed and connected.
        We might want to have separate threads discussing each of these topics; I'm thinking to do that as an alternative to a conventional white paper in Word or Pages, just for the purposes of information sharing.
          I'm sure I don't need a 5 channels of Ncore. And I'm sure I want one ;-)
          If you look at the cost it will run 130 *3 = 400 euro for for the SMTP, then 6 * 80 = 500 for the NCore. So we're at 900 euro for the basic.
          What I do not yet know - and that I'm considering as we go along, is how many features of Jons System board I will add to the 5/6 channel amp. That will depend on the cost and size.
          One direction that I might be following is to max out on the nice stuff for the center channel and save a bit on the rest of the channels. If so then the center channel will be full mono with a single SMTP for itself, while the 4 other channel will use one SMTP pr. 2 channel and maybe less stuffed system boards.
          Or... I just go full blown kamakazie on all channels ;-) Ehh, the 4 channels will have to share two SMTP's - that's given in any of the configurations beeing considered.
            Thanks Jon, I hope I'm not pushing you. I have an amp so there is no rush. The only thing that's bugging me a little is the NC400 with the SMPS600 was optimized by Bruno to be the DIY'ers perfect match and the OEM NC500 and NC1200 versions were left to be optimized according to the OEM's flavor. Just using the SMS12A700 made for UCD and their input board seems quick but I'm wondering probably like you if there is more to be had with a little care. I would rather not rush even though Tek's deal is fantastic and see what your tests come up with. This will probably be an amp I'll stick with for a while and I have some work to do with the display as well as needing spring to do a wood front for the case version I'm planning. I'll start my thread when I have the display up and working.
              Darell, what do you mean by "have the display up and working"?
              Does this include selecting part, Arduino board and so on?
              I'm very interested in hearing about this so feel free to make a thread and tell something about it. I have long over 10 years experience in software development and coding solutions as well has beeing tech lead and team lead on several projects. And I have tried a bit Ardino stuff as I used a Ardino board on my water cooled router (rele control, temperature monitoring, water pump monitoring as well as controlling router speed based on switch i put).
              A bit rusty these day as I'm more working on software system design and business analysis - but still interested in the nifty gritty details. Have some arduino boards laying around at home as well ;-)
              So - feel free to start a thread about this :-)
                Digital or analog? Hypex nCore 400 Amplifier discussion & Build thread
                This has been in the works for a while, but today I actually got around to ordering the nCore 400 modules and SMPS600 power supplies- I've already got the chasis, special power cords, and a variety of other bits.
                Chasis are being sourced from an acquaintance at Hexateq in Belgium; this...
                31 January 2014, 12:21 Friday
                Some comparisons measurements of commercial CLASS D designs, NCORE based and others
                Let's lead off with the Theta Prometheus, one of the earlier nCore OEM designs, as reviewed on Stereophile. $12K per pair.
                Theta Prometheus, frequency response at 2.83V into: simulated loudspeaker load (gray), 8 ohms (blue), 4 ohms (magenta),...
                31 December 2015, 13:07 Thursday
              • Supernova
                Class D
                by Supernova
                I see a lot of people have the hate on for Class D amplifiers in various forums. I have been looking into nCore NC500's or Pascal's and was curious why it's such a touchy subject. I have some A/B amps and a class D amp and like them both. I've never heard a class A or tube amp. I've read somewhere the...
                02 October 2017, 01:51 Monday
                NAD goes NCORE
                NAD has released a new power amplifier based on NCORE technology, though they haven't identified which one- as the web site says it's using the latest, I would presume that means it's NCORE 1200 derived.
                http://nadelectronics.com/products/maste...
                08 September 2014, 15:34 Monday
              • Armbender
                Emotiva XPA5 vs Wyred MC5
                by Armbender
                Looking at possibly upgrading my current XPA5. Wondering if anyone has any direct comparison to the Wyred 4 Sound MC5 that could give some results
                My current set-up is listed below.
                Elacs run at 4ohm if that makes a change in opinion
                20 November 2011, 18:28 Sunday
