How would an increase in speaker cables length affect cam600 performance?
  • Eliav
    • 484
    Hello all
    I have recently came across a vexing issue. I used to own a 2 meter speaker cable ( not mentioning brand, just saying it is a reference class very expensive cable). I recently replaced it with a longer cable (2.5m),same brand. I noticed definite decrease in bass reproduction. Not saying dramatic, but an audible decrease for sure. Checked with classe, the cable manufacturer,and textbook of physics, all indicate there was no way an increase in .5m should cause the amps to fail reproducing the same bass it did with shorter cables .Yet, I learned to absolutely trust my ears, and I am positive something has changed. Needless to say I did not change room acoustics, speakers position, etc.
    Anyone's experience with a similar issue?
    Eliav
    :T Socrat
  • madmac
    • Aug 2010
    • 3122
    If you did not move the speakers farther, then why the longer cable?. In any event, even though the cable is of the same brand, the materials used and wires inside it are probably different than in your old ones. I've changed some wiring over time and have noticed a difference every time when I change them. Sometimes better, sometimes worse. Wires DO make quite an effect on the sound produced....including interconnects.
    Dan Madden :T
    • slauten
      • Aug 2011
      • 105
      My guess is you moved equipment location, and left the speakers in the same position. To my knowledge...the cable manufacturers claim a break in period is needed to sound their best. If the new cables are identical, with exact same specs for materials used...then there should not be any difference. Except break in period.
      See Ya,
      Steve
      • Eliav
        • 484
        Thanks guys.
        I got a longer pair since I was anticipating a change in my room, which never took place eventually. trust me NOTHING changed except for the .5 m addition of the SAME cable from the same manufacturer and same brand.
        My listening room is a music shrine. Every spot from speakers position to sweet spot has been tested, measured,calculated and marked. No one gets in this room, and NOTHING moved or changed when I replaced the new cables. Both cables were broken in well beyond the manufacturer's recommended time. The reason I posted this question is what I hear does not make sense. Dont get me wrong, the sound is amazingly detailed and 3 dimensional,yet I still feel the bass is a bit dryer and with less punch than it used to be. Is this just my imagination?
        :T Socrat
        • stuofsci02
          • 1241
          Originally posted by Eliav
          Thanks guys.
          I understand why you have an issue.. While there will be a small resistance increase due to the longer cable, this will be so small it there should not be an audible difference.
          Do you have any test equipment were you can swap out the cables back to the old ones and compare using real information?
          Maybe there is an issue with the terminations..
          Main System:
          B&W 801D
          Emotiva USP-1 Pre-Amp
          Chord SPM-650 Stereo Amp
          Oppo BDP-105
          Squeezebox Touch
          Second System:
          B&W CM7
          Emotiva UMC-1
          Emotiva UPA-2
          Oppo BDP-83SE
          Grant Fidelity DAC-09
          • Oddiophile
            • Jul 2008
            • 173
            Eliav,
            See if you can get another identical set of the 2.5 m cables from the dealer and substitute them. Perhaps there is some weird issue with that particular set of 2.5 m cables that you have.
            • Eliav
              • 484
              I don't think A/B comparison will be possible. The dealer can send me his own pair which are 4 m long. I can theoretically check for diminishing bass with these compared to mine, and draw a conclusion by deduction. I did speak with Classe, they say that the CAM600 should not have any problems with the increased resistance due to lincrease in length. Cable company claims that their recommended length for best performance is 2.5-4meter.in fact, they do not recommend anything less than 2 meter (I wonder why.. :W ). How do I check the terminals quality ? These are factory made golden banana ones, they all feel solid and are nicely secured into my 800d.
              The other option is to send the cables to the manufacturer for lab testing, they may detect an issue.
              :T Socrat
                Just a crazy thought... but is the 2.5 cables brand new..... and your other cables broken in....
                Could there be something to "break-in" of a cable.... Do you have your others and when you put them on there's a difference? Give the 2.5s a few days of use (maybe 30 to 50 hours) and then swap back and see if there's a difference... I bet you'll see there's no difference after that time....
                • stuofsci02
                  • 1241
                  What exactly happens during cable breakin.... Sounds like audio religion to me.
                  Main System:
                  B&W 801D
                  Oppo BDP-105
                  Squeezebox Touch
                  Second System:
                  B&W CM7
                  Emotiva UMC-1
                  Emotiva UPA-2
                  Oppo BDP-83SE
                  • slauten
                    • Aug 2011
                    • 105
                    The cables need to be emotionally attached to the system before they can produce the best sound! In addition...as the cables get warm they outgas any remaining volatile organic compounds allowing the music to flow unrestricted.
                    No charge for the humor
                    Steve
                    • madmac
                      • Aug 2010
                      • 3122
                      I've heard of component break in (I'm still skeptical of this too), but I have never heard of wire break in??!!. It's not entirely impossible though but probably very minor in regards to sound output and it's quality.
                      Dan Madden :T
                      • slauten
                        • Aug 2011
                        • 105
                        I somewhat believe a cable could have some minor break in period...my opinion is based on several cable/interconnect manufacturers claiming a break in period is necessary before it will sound it's best. Of course I'm drinking the coolaide because I bought into the concept that better cables sound better. I do click my heels together 3 times before I turn my system on...I know that helps me listen better.
                        Can you hear me now?
                        Steve
                        • madmac
                          • Aug 2010
                          • 3122
                          Steve
                          Different cables absolutely affect sound quality, regardless of their cost. Both in speaker wire and interconnects (Break in or not). Experiment until you find ones you like. :T
                          Dan Madden :T
                          • slauten
                            • Aug 2011
                            • 105
                            I totally agree...just wanted to cover my bases. There are some members on the HTGuide forum who would disagree that interconnects, speaker wire, along with related items such as better power cords can't improve sound.
                            See Ya,
                            Steve
                            • madmac
                              • Aug 2010
                              • 3122
                              See Ya,
                              Steve
                              I once changed the interconnects from my CD player to the amp and heard a very big improvement in sound. What is particularly interesting is sub interconnects. I've changed them a number of times with very different 'timbers' and results of bass being produced which I find very interesting. Remember, wiring is getting better and wires from 10 years ago are not like new quality wiring being produced today. Also, it's possible that the internal wiring can get 'tired' , hard, brittle, and easily damaged....sort of like old home electrical wiring.
                              Dan Madden :T
                              • stuofsci02
                                • 1241
                                See Ya,
                                Steve
                                Yes... This is me for speaker wire and power cables... Also for bi-wire...
                                Main System:
                                B&W 801D
                                Oppo BDP-105
                                Squeezebox Touch
                                Second System:
                                B&W CM7
                                Emotiva UMC-1
                                Emotiva UPA-2
                                Oppo BDP-83SE
                                • aarsoe
                                  • 795
                                  To me the only logical explanation would be differences, physically, in the cables.
                                  It could be difference in the cable used,as in different production batch with slightly different mixture of metals. Or it could be something as simple as the person attaching the plugs at the end of the cable twisted them 3 times instead of 4 on your original cables. But I am guessing and have nothing solid to back it up.
                                  • Horacio
                                    Cables for 804S + tubes?
                                    by Horacio
                                    I'm starting my search into speaker cables for my 804S driven by McIntosh MC275 and would very much appreciate members' insight into what has work for them.
                                    We all know these threads weren't allowed until now, and this is sort of an experiment, so let's behave! :T
                                    Please note...
                                    09 September 2009, 20:26 Wednesday
                                  • myou
                                    Cable Fables
                                    by myou
                                    A family members works in the digital TV production business and as such, know's a think or two about home theatre equipment. Having recently purchased some components, he readily dismissed the importance of having top end cables in most cases. Excluding better quality speaker cables...
                                    03 August 2004, 10:36 Tuesday
                                  • TSG
                                    I got some new speaker cables..
                                    by TSG
                                    Or should I say some "Zu" speaker cables?
                                    I replaced 12 gauge Monster Cable with Zu Julian cables and I can't believe it. The slight edge (harshness?) that was there is now gone. Definitely more fluid... It's amazing! One step closer to heaven...........
                                    13 March 2003, 00:23 Thursday
                                  • SwainDtV
                                    Issues regarding SSP-800 sub output
                                    by SwainDtV
                                    I’m posting this in HTGuide and AVS forum.
                                    I have a Velodyne powered sub connected to my SSP-800 with XRL cable. When I press mute or when a digital input (HDMI/coax) is interrupted e.g. movie pause, transition between menu and movie, I get one or more thumps from...
                                    07 September 2010, 07:31 Tuesday
                                  • NeutralMAN
                                    DIY Power Cable - Cable Only
                                    by NeutralMAN
                                    Hi all,
                                    I have been playing around with making my own power cables. Just the cable not including the power plug and IEC plug.
                                    I have some questions:
                                    - What are some good designs regarding the power cables?
                                    - Can I just run some shielding around the PVC/etc....
                                    25 August 2005, 03:40 Thursday
