I know that the mono's are perfect for 802's yet I'll also have to built a m/ch system based on them so I thougt about getting a multichanel amp first and add the monoblocks later when budget allows. Can any of Classe's multichanel amps do 802's justice?
Can Classe multichanell amps drive B&W 802D?
I have a Ca 5200 driving them and a HTM 2D and 804S rears. No sweat. It was a dramamtic change from my Rotels. I am sure mono will be better but alsi much more money now that t he CAM 400s are gone except used. The CAM 600's are $7000 a piece!!!- Bottom
Yes that is brutal $21,000 to drive three 802DOriginally posted by ray5I have a Ca 5200 driving them and a HTM 2D and 804S rears. No sweat. It was a dramamtic change from my Rotels. I am sure mono will be better but alsi much more money now that t he CAM 400s are gone except used. The CAM 600's are $7000 a piece!!!
ops:
Farming looks mighty easy when your plow is a pencil, and you're a thousand miles from the corn field."Dwight D. Eisenhower- Bottom
by AntonkkI know that the mono's are perfect for 802's yet I'll also have to built a m/ch system based on them so I thougt about getting a multichanel amp first and add the monoblocks later when budget allows. Can any of Classe's multichanel amps do 802's justice?-
Channel: Club Classé
Channel: Club B & W Speakers
by SRT-10 ViperI just switched amps from a Krell TAS 200Wx5 Amp to a the Classe CT5300... All I can say is wow! I had two other guys over helping install the amp and we did a test prior too/after the install. We all sat there amazed at the improvement in sound. I have 2 Lamm 1.2 Reference Amps for the front and the...-
by radimHello.
I would like to change radically my system (as far as I can make understood with my dealer).
Lately I listen only 2ch music and only sometime dvd or multichanel. Therefore I want only very good stereo and no HT. My budget is restricted and I cannot have this two systems on high...-
by beden1I have the opportunity to purchase a used pair of 802's, and had recently been focusing on getting a pair of 802Ds that I had been auditioning in a B&W dealer store. I have not heard the 802s to compare.
I really like the 802Ds as the highs and mids sound very articulate to me, and...-
- Loading...
- No more items.
