Port Tuning Methods
  • mjperk
    • Jan 2018
    Port Tuning Methods
    I have been helping my father build his very first set of speakers which are the Sunflower Redux from Paul Carmody. More specifically, I have been trying to provide technical expertise and guidance for him as he constructs it half way across the country where he lives. I have never built a set of speakers before either, but I am a mechanical engineer by profession and have some car audio experience in my past, so I like to think I can at least learn what is needed to get the job done right if I know where to start. It has been an an interesting and fun experience, and he is getting close to the point where it can hooked up to actually play something through it!
    I have read several resources regarding port tuning, that in essence, said calculations will only get you in the ballpark and true port length should be tweaked during the last few steps of construction. If I understand correctly there are several methods to determine what a port is tuned to, but I am unsure about which methods will work best (or at all) and am looking for more information in general. He does not have any audio analyzers or precision acoustic measurement tools at his disposal. I'd guess wouldn't want to justify a huge cost in acquiring them either since I don't think he is looking into speaker building as a long term hobby and may only build one other set depending on the outcome of this project. The methods and ideas I am aware of are listed below, but please correct me if I am wrong or have missed something. I am open to all good input on this one so please set me straight.
    FYI if it helps to answer my question, the box is ~43L and uses Dayton RS225-8 woofers. Paul says the tuning frequency should be around Fb=23 Hz which would be a 2" diameter x 8" long round vent.
    1.) Measure system frequency response using a calibrated microphone
    I infer that this is the best way to do it, and if I understand correctly is simply measuring the frequency response output with a signal generator input. I didn't look too much more into this one after I saw the price of OmniMic. I guess this post is really asking about alternatives to this method.
    2.) Measure impedance of the woofer
    I believe this one basically amounts to incrementing a frequency input and measuring the impedance(resistance?) across the driver at the same time. I was thinking that we could use an iPod with test tones and play something from around 15Hz - 50Hz one at a time in ~5Hz increments or so. By running the multimeter leads through the port tube we could then measure impedance and plot it very roughly vs. frequency until we mapped out the double-peak bass reflex impedance chart. IIRC, the actual Fb is the frequency at the lowest impedance point in the valley between the two impedance peaks. I would expect by starting with a port tube cut an inch or two longer than the calculated length, that the interpolated Fb from the measurements would be lower than the 23 Hz target. So then in theory, this process could be repeated and the port could be trimmed in 1/2" increments until the impedance valley measured for a given frequency sweep came down to the 23 Hz region. Of course once the general Fb was found after the first round of measurements, the frequency tones could be varied in 1Hz increments for a smaller region so as to just save time and get more accurate results.
    I know it would be pretty tedious, but I am wondering if this method is even valid. One other concern I have is that I'd guess his multimeter will probably only measure DC resistance and likely does not have a way to measure true impedance. Given that impedance has AC components, I am unsure if this method would work using a DC multimeter. Surely the two peaks around the Fb would not be accurate, but wouldn't the valley (the part I think we care about) still be apparent enough to determine the corresponding frequency with some degree of certainty? After all, I think that at this resonant Fb where impedance is at a low, that phase angle is also 0 degrees which would then imply that there are no imaginary components to the impedance and it is completely equal to DCR in that region. Is this correct and would this method work using a DC multimeter?
    3.) Visually observe woofer excursion
    If not mistaken, when a woofer in a tuned enclosure is playing at the tuning frequency, that excursion is nearly zero and the port is doing most of the heavy lifting--most observable sound should be coming from there instead. So then the same test tones used in the method #2 above could be played in ~5 Hz increments and eventually 1Hz or 2Hz increments to identify the Fb by looking for when the woofer cone moves the least amount. As I think about it, I believe this may actually be using the same underlying principles as method #2 except instead of measuring impedance we'd just be visually observing the effects. I'm not sure if that's actually true or not, but is this method good enough to get within 5 Hz of the target Fb or so?
  • chrisn
    • 175
    Welcome! The easiest (to me) way to do this is to measure the impedance with a Limp jig: http://www.midwestaudioclub.com/resources/easyzma/ Another "method" would be to buy 2-4 extra vents, cut an inch or two longer or shorter, and swapping them in to see which sounds best in the room.
    • Matt M
      • Jul 2014
      • 86
      Maybe I didn't read carefully enough, but what I do not understand, is why you want to do "port tuning" in the first place. You have a given design (Sunflower redux) that specifies volume and port size. What do you want to accomplish?
      • jquin
        Port tuning measurement
        by jquin
        Hi All
        It's been many years since I have posted about speaker building by my son now has an interested in the topic.
        I have built a new Modula MT box that will fit in the corner of the room but when it comes to measuring the port's resonant frequency it has been nothing but frustration....
        19 February 2022, 18:34 Saturday
      • Eton
        Too many impedance peaks?
        by Eton
        Can anyone tell me why I’m seeing three impedance peaks instead of two on this Dual ported Dual driver design? Both test ports are of equal length 8 inches each. Changing port lengths does not reduce the two peaks only the tuning. Even if I remove one port and block the hole I still get two impedance...
        10 May 2014, 13:07 Saturday
      • BURRometer
        Problems with port tuning (Noob)
        by BURRometer
        I'm working on a ported enclosure for my RS225. UniBox suggests a 25cm x 3" port for a 50L with an Fb of 29.5hz. I've used ThomasW's port measuring procedure shown below. Odd results (for me anyway), so I tried a few variations on port lengths out of curiousity. Here's what was measured:...
        17 June 2006, 18:47 Saturday
      • Martyn
        Box and Port Tuning Frequency
        by Martyn
        I have a few rudimentary questions that I'd like to ask. In each case, I thought I'd try to do it such that they are easily searchable and provide a useful resource for non-expert speaker builders. Here's the first question:
        Let's start by assuming that you are looking at woofers for...
        14 October 2019, 13:11 Monday
      • MarcE
        Port diameter trade-offs: midrange SPL leakage
        by MarcE
        Hi everyone!
        I have been playing around with Unibox and have a few questions about some port length trade-offs. First, I have actually heard this driver in the 3" port configuration, and there was not any problems with the port configuration, i.e. no port chuffing or obvious midrange...
        19 July 2007, 09:32 Thursday
