I have a few rudimentary questions that I'd like to ask. In each case, I thought I'd try to do it such that they are easily searchable and provide a useful resource for non-expert speaker builders. Here's the first question:
Let's start by assuming that you are looking at woofers for a ported design, and that you are using Unibox. How do you choose Fb, the system tuning frequency?
My understanding is that you want the two peaks on the impedance chart to be about the same height (and that Fb will be the low point between them), and for Fb and F3 to be close to each other. How close is close enough?
Your design criteria might impose a limit on the physical size of the box, so you try reducing Vb, but this pushes F3 up. Since a low F3 is another of your design criteria, what do you look for in arriving at a happy compromise?
You decide that you can tolerate a significantly larger box after all and find that this gives you the F3 that you're looking for, but the F3 has now drifted further away below Fb. Again, how do you arrive at a happy compromise?
What else do you consider when deciding on system tuning?
