Cracking/Popping sound from Jeff Bagby's Baby Boomer
  • daniel4381
    • Jul 2014
    • 13
    I bought a Baby Boomer Subwoofer kit from Meniscus with the PR option ( http://meniscusaudio.com/baby-boomer-p-1389.html ). I have constructed the cabinet exactly according to the build plan.
    MDF is 3/4 inch all side except the front baffle is 1" (two 1/2 inch MDF glued togather). Inner dimension of the driver chamber is 10.5 sq inch and Plate Amp is put into a separate chamber and the wire hole is sealed properly. Top, back and the bottom of the driver cabinet is wrapped with supplied wedged foam.
    When I first time connected the Sub and played a deep bass test tone, I found that the one of the PR making very odd rattling sound. I opened those again and found that the extra weight in the PR is loose and tightened both the PR weight and that rattling sound is gone. But, now when I increase the volume a little, there is a cracking sound from the PR and may be from the Subwoofer driver. It seem that the speaker can't take the load, but the sound is not high at all or the sub volume is not much, it is less then 1/4 of the volume. I thought that may be as it is placed on the floor and it happening due to the vibration with the floor. I stood up on the cabinet to reduce the shake and I understood that it is not happening due to the vibration, it is probably due to the PR. I have tested with my 2nd Sub (Yamaha SW160) and it does not make such sound. I opened the divers and found no physical damage anywhere.
    The kit contains Dayton 1 x DCS255-4, 10" Woofer, 1 x SD300, 300W sub amp, 2 x Dayton Audio SD270-PR 10" Passive Radiator
    A video of the sound is attached herewith https://drive.google.com/open?id=0B8...0RhazRNOGZqY2s
    Can someone suggest and help me out please.
    • 16197
    What frequency did you test these at, when you say you played a deep bass tone? Ported and PR systems will run into trouble if you drive them below their tuning point- the driver is unloaded and will have a lot of travel without much acoustical output.
    The problem could be with the amplifier, too- the only way to tell would be to try a different amplifier with your speaker, or to try that amplifier with a different sub.
    Can you do a frequency sweep with test tones from a computer, for example, 100Hz down to 20Hz, and identify if the issue is frequency dependent?
      What Jon says you need to test these with a different amplifier. This doesn't have to be a plate amplifier for a sub just anything really. Feed it with a signal from your PC as Jon says to drive the sub and see what happens.
      I have encountered noises like that from both amplifiers and drivers, we need to find out which one is to blame!
      You can always remove the PR to get that out of the picture and see if the noise still happens. Just be careful with the volume with the PR off as the sub driver will flap about a whole lot more without the cabinet loading it.
      • augerpro
        • 1871
        When you said pop or crack I was thinking amp clipping like the others, but when I watch the video it looks more like something is loose, or torn, like a dustcap or surround.
        ~Brandon 8O
        DriverVault
        Soma Sonus
        • daniel4381
          • Jul 2014
          • 13
          Thanks to all, I found air is leaking from a mounting screw hole. I am going to change the Cabinet and seal the leak as soon as possible, let's see. thanks again
          • shaqdaddy86
            Sub Amplifier Relay Question
            by shaqdaddy86
            I recently purchases a subwoofer amplifier which does not have an auto turn-on feature. I was wondering if there is a way I can get it to turn on when I turn my receiver on. The receiver has a switched outlet, so I was curious if there was a way to build a relay to turn the sub amp on. I cannot directly...
            27 February 2006, 13:32 Monday
          • Jonniebravo
            Sub amplifier questions
            by Jonniebravo
            Building dual 15" subs for my theater. Presently using 1 Tempest-X 15" driver. Going to be using 2 Tempest-X 15" either in the same cabinet or seperate cabs. Eliminating PartsExpress 1000 watt plate amp with a QSC GX5 amplifier. Question is, how do I trigger the amplifier remotely or...
            27 January 2010, 12:07 Wednesday
          • SammyXP
            Sub Amplifier in its own enclosure?
            by SammyXP
            I just got in the materials I need to build my first DIY HT sub and looking at this Bash 300w amp thinking that it would compromise the seal and integrity of this massive box. All the effort into making the box rigid and airtight seems in vain with this thin plate and switches with some sealant around...
            20 October 2005, 12:13 Thursday
          • Tobias Funke
            Halcro MC20 Power Amplifier
            by Tobias Funke
            "I have just heard the future of home Hi-Fi"
            Big call, well "Rolling Stone" said it about Bruce Springsteen and I have modified the line for this amplifier. Not a big call when you hear this little baby.
            Have just ordered one from AudioLifestyle in Bridge...
            03 July 2005, 04:23 Sunday
          • mfishmike
            Looking for a Rotel 1065 tech for a sub pre-out question
            by mfishmike
            I've got the Rotel 1065 receiver/amp and it comes with two sub pre-outs. The manual tells me they are RCA 1.2v (or close), out to the subwoofer amplifier.
            The picture in my "avatar" to the left is my latest DIY subwoofer project. It has two active drivers and 4 passive radiators,...
            25 December 2005, 15:14 Sunday
