Minimalist enclosure for TB W4-1337
    • 3815
    Hey y'all, long time no see. I've been futzing around with no surround sound speakers for a while and finally just decided I want to throw something together real quick with some Tang Band W4-1337 drivers I have. Since they're full range, I could technically just mount them in a box and be done correct? I'd love to make them as small as possible. According to the spec sheet it just needs a box that's 0.1 cu ft vented. Does anyone have a minimalist design for this already?
    -Chuck
  • chrisn
    • 175
      • 3815
      Thanks, I've seen the Lineup series, just didn't understand the need for the XO.
      -Chuck
        • 3815
        And also hoping to build something much smaller.
        -Chuck
          • 16205
          Well, if you flush mount them in a wall, then you could just throw them together without a crossover. But if you put them in a box, you'll need to consider baffle step compensation, considering the dimensions of the enclosure. Often you don't need the full 6dB, but expect to use at least 5 dB. That's basically a series combination of L and R in parallel. Easy to simulate, probably the fastest way to get there without measurements is to use a Tool like VituixCAD which includes driver and enclosure modeling, and work up the BSC compensation network from the simulated response based on enclosure dimensions.
            • 3815
            Gotcha. If the XO is really necessary I'll just go ahead and build the R4s, since I also have the NeoCD3.0s sitting around.
            -Chuck
              If you're mounting them on a wall, in a small box then you will need far less baffle step compensation. Maybe just 1dB or none at all sometimes. These are only for surround effects which, as things go, is a fairly undemanding application.
