The Odd Couple.
    The Odd Couple.
    So I've been experimenting with the B&W FST, on and off, for a while and I've finally come up with a combination that I am pretty happy with. It certainly isn't where I thought I'd end up!
    The basic idea started when I saw the new SEAS coax drivers, I figured I'd like to give those a go, but didn't really have any real reason to do so, except to satisfy my curiosity. Then I got to thinking that the FST has the perfect surround for decent coaxial performance and the phase plug is easily removable. Indeed, unscrewing it leaves you with this.
    A nice flat pole piece with an M6 hole tapped through the middle and a decent amount of depth in which to sink a tweeter. The only trouble is that the internal coil former requires a tweeter around 29mm in diameter to fit properly. This isn't easy to find. I first tried out the OT19 from Vifa. I already knew that this would be too wide to fit properly but I thought that it might be possible to mill down the outside to make it fit - no go, unless you want to risk damaging the tweeter. The only other options I could find would be to acquire some KEF replacement domes, some very unknown car tweeters from Ciare, or to try giving the ND16 from Dayton a go. I wasn't even sure if the idea would do what I wanted it to do, let alone work properly, so the inexpensive Dayton's fit perfectly for an experiment. I had already used these in a small loudspeaker and I had some concerns about their low end capabilities as the design would necessitate a cross no higher than 2500Hz. In a non wave-guide loaded design this tweeter really requires an xover around 3.5kHz, so the hope was that the gain, provided by the cone loading, would help it in this regard.
    Now the ND16 isn't perfect for the job as it's external diameter is bigger than 29mm, but whereas the OT19 cannot be milled down, the ND16 can. Then a pair of contacts need to be transferred from the back of the tweeter through the front.
    Here is a picture of the milled down tweeter and illustrates how I got the contacts through to the front.
    And then here's a rear shot with an M6 screw glued to the back.
    And two shots with the tweeter mounted. (Yes the FST sphere still needs finishing ops
    Now I was very curious to see how the tweeter measured, all things considered wave guides and coaxes tend to have some issues, so this was always a bit of a gamble. The on axis curve was quite ugly, but they always tend to be. So slightly off axis things looked like this.
    The only real issue is the dip at 12.5kHz, otherwise it looks great. The 12.5kHz issue varies in how bad it is with how far off axis you go.
    Filtering this was surprisingly easy with only one notch being required along with the usual high pass elements.
    Now I figured that the top octave issue would be fairly audible but it's far less of an issue than I thought it would be. I have read a number of comments, from wave guide people, saying that it is often best to ignore top octave stuff so long as what's below is absolutely fine, so maybe this is a prime example of that in practise.
    That aside it sounds great, a $10 tweeter with a $200 mid isn't what would usually be prescribed but in this case it works very well together. I've measured the distortion at realistic listening levels and aside from a slight increase in 2nd and 3rd order around the lower end of the tweeters range, it seems to cope absolutely fine. There isn't an increase in 4th and 5th, which is what I was mainly concerned about. It'd be nice if Scanspeak would release a tiny Be tweeter, but I can't see that happening any time soon!
    There is obviously some room for improvement and over the next few days I am going to be experimenting with DIY phase plugs in an attempt to help with the top octave issue as these are usually created by throat/tweeter diaphragm issues.
  • Jonasz
    • 854
    Nice! :P
      Agree, quite nice. I wonder if there's anything you can do with felt or otherwise on what remains of the tweeter frame to mitigate the dip in response. I'm thinking even a ring of felt might make a difference. Many of the better WG tweeter responses I've seen actually cover some of the surround and outside edge of the dome (without actually touching)
        Mmm thanks guys, that's an interesting idea, I have got some felt. KEF seem to go crazy with their 'tangerine' style stuff, I believe it's all about breaking up the wave front directly in front of the tweeter/in the throat, to prevent interference from creating the nulls in the top octave.
          Very neat threads. It is always interesting to see something totally different.
          I would be interested in seeing how you made the sphere too.
            I have photos that document the building of the sphere, there are just loads of them, I will write it up at some point
            I have been doing some more off axis measurements of these and it's no surprise that they actually sound good. When you get to around 15-20 degrees off axis the top octave hole completely vanishes and remains absent all the way out to 90 degrees. Besides the top octave issue, the power response is excellent. Still that isn't going to stop me trying to improve things.
            • DS-21
              • 171
              The Odd Couple.
              Cool! I bet the Dayton is actually a better choice than most, because it has a waveguide "snout". Another one to look for is the old Aura NT1. It might be a bit bigger but IMO it was a really good tweet. Wish I had a set to send you.
              As for phase plugs, remember that the KEF tangerine is just a swoopier version of the old Atlec phase plugs.
                • 16205
                Yup, that's my experience, too, and why the tweeter choice and details of construction matching up to the initial waveguide are so critical- it's hard to get the smoothness of the Modula MT XE, took a few design passes and evaluating several tweeters. Always the problem is destructive interference in the 10-13 kHz area.
                  Yeah, it's one of the reasons I like the little Dayton, there's very little that it does wrong. The Aura was on my short list too, it's a shame that it isn't around any more. It's motor appears to be a little more advanced, or better developed, than the Dayton. It has significantly lower levels of distortion down where it counts. My only concern would be whether or not it would fit! In theory a 19mm dome, with a traditional narrow surround, should fit it just depends on if the rest of the construction would lend itself to being chopped up.
                  Interesting.
                  • Landspeeder
                    • 273
                    Sub'd!
                    My Builds: https://www.htguide.com/forum/showth...731#post593731
                    • Jonasz
                      • 854
                      Maybe this could work also? Probably need a little higher crossover than 2500hz though...
                        That one was also on my short list, or at least some small dome from Audax. I have used one of these before and you are right in that they don't really reach down far enough. This wouldn't be ideal for a directivity match although it wouldn't be bad. If you didn't want to modify the tweeter then it would probably fit straight out of the box.
                          I have done a little bit more work on this. I've tried the felt and that didn't really do anything and I've tried holding various shapes in front of the dome just to see what affect they have. So far I've managed to find shapes that help the on axis response but they all seem to fudge with the off axis in one way or another. I suppose my problem is that the off axis response beyond around 15 degrees is superb and I'm wondering if it's possible to come up with some sort of design that will help that 0-15 degree region, but hardly affect 15+.
                          Some of KEF and TADs designs don't use any kind of phase plug yet still keep the top octave looking rather nice, I am assuming that this is down the shape of the throat and how the voice coil of the mid transitions into the cone of the driver. There's not a lot I can do about that here though!
                          • Juhazi
                            • 239
                            I don't believe that on-axis tricks are necessary. What was your measuring distance? Please show us off-axis at 15,30 and 60¤ too! What happens if you unscrew the tweeter say 3-5mm?
                            • JonP
                              • 692
                              Now, that's a cool hack... Maybe a second ND16 up top as a super tweeter, crossed to take over below that notch? That would be a B&W kind of thing, too, no?
                              I've used the Aura, and the Dayton ND20, and I think they are EXACTLY the same, from the outer chassis point of view. So, possibly the same inability to file it narrow enough, if that's the case. Don't sacrifice a NT1 for naught! Try a ND20 first.
                                Nah it doesn't need a super tweeter, the notch is only a problem on axis and the close off axis.
                                Here is an image of the off axis response.
                                These were taken very crudely with the loudspeaker situated for normal listening and by moving the microphone around. It's a pain to get out the turntable for proper off axis measurements, but they are good enough to see what's going on.
                                The red curve is directly on axis, orange is about 15 degrees off axis, the yellow curve is 25 degrees off axis, dark blue around 45 degrees and the turquoise about 65 degrees off axis. In fact these show really why it sounds very nice, the only real issue is the top octave one, but while you have a notch in the close off axis you actually get a small hump in the far off axis, and this will help to balance out the presentation of the top octave. Ignoring the top octave issue the rest is really rather nice
                                And I just realised that in cropping the image I removed the scale on the vertical axis. Each major line is 10dB.
                                  • 16205
                                  Do you notice any difference in presentation with the bump in the response in the 5-6 kHz region? Apart from these two issues this looks very nice.
                                    I haven't noticed anything. In previous designs peaks in this area have been rather distracting, causing excess sibilance on certain material and annoying the hell out of me. I didn't do very close off axis measurements, say 5 degrees or so, but the initial design work at the top of the thread is perfectly flat and is obviously done at less than 15 degrees because the top octave issue is worse than the 15 degree measurement. If the peak is only present directly on axis that would help to explain why it isn't a problem.
                                    • ttan98
                                      • 153
                                      HI,
                                      I notice the original ND16, the On- axis measurement there is a dip around -2 to -3 dB in the 10-15Khz region similar to what you got, maybe not as deep. The FR curve of the ND16 can be found here:
                                      http://www.theloudspeakerkit.com/nd1...-tweeter-6-ohm
                                      The mounting of this tweeter to the woofer looks quite good except the I can see external wiring, how are you going to solve this problem?
                                        Originally posted by ttan98
                                        HI,
                                        Yeah that's a good point. Wave guide loaded tweeters usually show some kind of cancellation issues, or directivity issues, somewhere in the top octave. If the ND16 is predisposed towards an issue in the same area then this could explain why it's quite severe in this case.
                                        I don't see it as a problem, so it's not going to be fixed?
                                          Tightly twisting or braiding them would make them more aesthetically pleasing.
                                          • ttan98
                                            • 153
                                            After mounting the tweeter to the metal body via the screw you attached to it, did you glue the tweeter to the woofer membrane, or is it isolated from the woofer's membrane?
                                            If it is not glued, would the woofer sound different?, normally the dust attached the the woofer holds the woofer membrane together in give it correct woofer Freq. Resp..
                                              It's isolated, the cone of the midrange driver needs to be able to move freely, otherwise you'd be locking the voice coil firmly in place. The FST doesn't normally use a dust cap, it uses a phase plug. This fixes directly to the top of the pole piece and isn't attached to the midrange drivers voice coil either. Changing from the phase plug to the tweeter does alter the midrange drivers frequency response a little, but only quite high up, like at 5kHz+ etc. For a good directivity match you need to cross this no higher than 2500Hz, so that's well away from where the phase plug would normally be affecting things.
                                              • DS-21
                                                • 171
                                                Andrew Jones convincingly showed on DIYA that what marketers call a "phase plug" on hifi midranges and midwoofers is really just a cosmetic pointy bit atop the pole piece.
                                                  Haha, yes, that is normally the case, but in the case of the B&W it does alter it's response at the very top of it's range. B&W use this driver up unreasonably high, crossing very shallow at 4kHz. Phase plugs also assist in helping to keep the voice coil cool.
                                                  I don't remember the exact changes that occurred, with and without the phase plug, mainly because they were way outside the range that I would be using the FST within anyway, but they were there.
                                                  • Tim Eagles
                                                    DM603 S2 tweeter repair or cosmetic issue?
                                                    by Tim Eagles
                                                    I have just had my eyes opened to the fact that removing my tweeters from a DM603 case would not be as hard as I thought, but from users experiences with bonked tweeters, or in this case, a childs delightfully directed poke on both tweeter domes, would you recommend disassembly and repair of what I...
                                                    19 January 2009, 19:17 Monday
                                                  • marshahu_cr
                                                    Best Speakers for Denon 1705
                                                    by marshahu_cr
                                                    Long time no see. Good to be back here again.
                                                    I am basically aiming for a budget 6.1 Home Theater solution with a DVD Audio and SACD player. I am intending to use this setup to output positional audio from EAX 4 compatible PC Games so 6.1 is essential - the more the better! So far I have...
                                                    05 April 2005, 14:09 Tuesday
                                                  • Joey_V
                                                    Which <$5000 speaker would you choose?
                                                    by Joey_V
                                                    I'm about to pull the trigger on the Martin Logan Vantage (within the week), but I would just like to hear your opinions as to which of the following <$5000 speakers would YOU choose for your 2 channel listening?
                                                    Lets do this for fun and not for serious sakes.
                                                    6.25%
                                                    2
                                                    Dali MS4 Euphonia
                                                    6.25%
                                                    2
                                                    Von Schweikert VR4jr
                                                    3.13%
                                                    1
                                                    BW 804N
                                                    28.13%
                                                    9
                                                    BW 703
                                                    3.13%
                                                    1
                                                    JMLabs Electra 927Be 25th Anniversary Special Edition
                                                    0.00%
                                                    0
                                                    JMLabs Profile 918Be
                                                    0.00%
                                                    0
                                                    AV123's Onix Reference 3
                                                    3.13%
                                                    1
                                                    Paradigm Signature 8
                                                    25.00%
                                                    8
                                                    Other, please specify in your post.
                                                    25.00%
                                                    8
                                                    07 January 2006, 03:27 Saturday
                                                    The Gallery - A place for your theater photos
                                                    by Lex
                                                    Are you guys aware we have a gallery for photos of your theater? I just wondered because not to many people are using it. I realize many people have web space for a site, or house their pictures elsewhere. I just wanted to make sure each of you are aware you can upload photos from your desktop to the...
                                                    17 January 2004, 00:17 Saturday
                                                  • Sonnie Parker
                                                    Movie Gallery Super Special on Previously Viewed DVD's
                                                    by Sonnie Parker
                                                    Yesterday I took our daughter Chelsea to Movie Gallery to rent her a PSII game for these few days she is out of school. When I walked in I noticed they had several racks of previously viewed DVD's for sale. The display read "BUY 2 GET 1 FREE" and most were marked at $9.99 each. The manager...
                                                    25 September 2003, 10:42 Thursday
