Need some build recs.
  • numberoneoppa
    • 535
    I have two friends that want speakers and I was looking for some good build recommendations because I haven't quite decided which designs to go for yet.
    Build 1:
    Floorstanding speaker for a relatively small bedroom - I was thinking a 6" driver in a 2-way configuration. Similar to the Copper-Project at PE, but not as expensive.
    Budget for drivers and XO: $200.
    Build 2:
    Floorstanding or bookshelf speaker for a bedroom - Thinking a 7-8" driver in a 2-way or a 2.5-way using two 5" drivers. Tritrix is being considered but I'm looking for some other suggestions.
    Budget for drivers and XO: $190.
    Thanks.
    edit: Really, I'd love to build something different than what I've built already:
    + North Seas
    + Tritrix MTM (TL)
    + Overnight Sensations MT.
    edit2: I still have those C-Audio metal tweeters (pair of Al and pair of Ti) if somebody thinks making a design out of those is a good idea.
    edit3: Hmmm, perhaps an RS150 or RS180 2-way for the first and an RS180 or RS225 2-way for the second? Just thoughts...
    edit4: Paul's Amiga is mighty tasty looking for builds 1 and 2. This is for a college student, though, I don't know if the Amiga will go loud enough for build 2... He wants "teh bass".
    -Josh
  • peepaj
    • Jan 2009
    • 50
    I know I'm a newbie and this is my first post here. I did build the overnight sensations designed by Paul Carmody, here's his web site http://sites.google.com/site/undefinition/diy . You might want to check it out. I can say that the O.S's sound very good, in fact after my wife heard them she wants a pair for the dining room first and another pair to replace the boston cr65's in the kitchen. I am trying to talk her in to letting me build one of his other designs. (will see) but for now the parts are ordered for next pair OS's. Let us know what you decide to built.
    • numberoneoppa
      • 535
      I have also built the OS before, and while fine for a small desk speaker, they're not quite big enough (and don't deliver the low-end response I'm looking for). The OS MTM would be considered as it is better at handling higher SPLs, but the FS is still pretty high.
      Edit: Considering the Swope MTM, Swope MT and Sietecerocero MTM a bit... though they all seem best paired with a sub, which I won't be using...
      흠..
      -Josh
      • Undefinition
        • 577
        Yeah, I think you should try the Amiga for at least one of them. They sound surprisingly huge. The F3 is pretty darn low for a 2-way; the weakness is the xmech of the RS180. If memory serves me, it's somewhere around 96-97 dB; this, of course, will be the "speed limit" of any RS180 design (using a single driver, anyway). I think it's about on-par with a lot of 7" woofers, though. The big eyebrow raiser for me, though, was when I realized that the Scan-Speak 8545K is roughly the same size, but will go all the way to 103 dB on its own! :E Now that's excursion! (I wonder if the Usher clones can get there, too?) But I digress....
        If your buddy wants 'teh bass' in terms of extension, something liek the Amiga should satisfy. If he wants more SPL, you'll want to look into an 8" woofer. 8" 2-ways are not very common nowadays--though you yourself have built one.
        • numberoneoppa
          • 535
          Thanks for the reply, Paul. Why aren't you sleeping at this hour?
          On the Amigas, what kind of juice would be necessary to power 'em?
          I would like to build something like the North Seas again, but unfortunately, the parts are currently not available and similar designs cost a good penny more.
          I've got about 2 weeks before I order parts - lots of time to think.
          -Josh
            Build #2, build these:
            http://www.htguide.com/forum/showthread.php4?t=35905 - build the MTM. Parts come in at $147. Same midwoofers as Curt is using in his AviaTrix. Great speaker. And it would be a CJD cross over, so something different. And easy to drive by inexpensive receivers.
            • mackintire
              • Jan 2009
              • 186
              Yep.... Either what K said or curts Avaitrix TL....which I am not sure where the plans are for?
              Another option would be Overnight Sensations MTM....which you could later add the subwoofer from the swoop HT.
              • Undefinition
                • 577
                I think just about anything would power them. They're a pretty easy load for any amp. I've played them on T-amps and HT receivers. Like most speakers, I think they'd probably sound their best on an amp with lots of headroom. But really, whatever you've got is fine.
                • numberoneoppa
                  • 535
                  Thanks Paul. So what do you think plays louder, the Sietecerocero MTM or the Amiga? They both have nearly identical woofer surface area, but the Amiga has more Xmax.
                  edit: I just worked up a complete BOM for 2 pair of Amiga including veneer, finish, brushes, parts, MDF, glue, 2 router bits, the whole nine yards, and it comes up to 650 dollars. This is about 80 dollars less than anticipated... High five PE for the volume discounts! I've already convinced one friend on this build, let's see what the other thinks. Building 4 Amigas definitely sounds like fun!
                  BOM for two speakers and "stuff" attached (.xlsx - Excel 2007/2010). I'm excited. (edit: updated Aug 06)
                  -Josh
                  • Undefinition
                    • 577
                    Not sure, but one thing I can tell you is that they probably sound pretty different. CJD and I voice things differently. And don't get me wrong, I really do like his stuff--I've heard most of it (not the Sietecerocero, though). It's just that he and I have different goals in mind when it comes to getting music to sound "right." Chris has an ENORMOUS music collection of stuff that was recorded really well. So when he voices, he's aiming for something that--when paired with a high-quality recording--emulates reality. Me, most of my music collection is stuff that's full of production; studio tricks abound. So I often just want to bring out the most that I can from these recordings. I want to dive into the sound and swim around, just have it envelop me (that sounds totally artsy-fartsy, but I can't think of another way to say it right now). Hence, my designs often sound very "large." Some people don't like it, but many others do. Either way, it's OK; tastes differ. I'm just glad I have the ability to design and build stuff that sounds "right" to me.
                      Paul,
                      I'm actually glad that you posted that. I was going to post something yesterday, but couldn't find a good way to say it. CJD strives for accuracy above all, clarity and detail - even if it exposes some warts within the recordings. (I really shouldn't put words into his mouth.) I've really enjoy it, but can see how others would prefer something different.
                      EDIT: The Sietecerocero or Ochocinco or whatever were calling them, don't quite have the emphasis on accuracy and detail of other CJD designs, because of the budget. They are a little bit more of a rocking speaker. But, they would still sound different than yours. I would love to hear them next to an Aviatrix, to hear the different voicing styles. It may or may not be big... don't know.
                      Paul, one of these days, we need to get together again.
                      • mischmat
                        • Feb 2010
                        • 139
                        These have always caught my eye for a small footprint speaker that is rather inexpensive.
                        • moosespeaker
                          • Apr 2008
                          • 3
                          I built the Cinderella's as my first DIY build based on Paul's (undefinition) comments on his home page. Cost in June 2008 was about $280 IIRC. If you go to the PE forum and look for moosespeaker (go to albums) there are a few pix of the build and finished speakers. I am very pleased with their sound.
                          George
                          • Anderton
                            New Amiga build
                            by Anderton
                            Hi all,
                            I recently completed Paul Carmody's Amiga speaker with some help from my girlfriend, built as a wedding gift for some dear friends of ours. I was unable to document the build in photos, but I thought I'd share the final product (placement in photos is temporary).
                            I...
                            21 September 2011, 00:20 Wednesday
                          • digi128pci
                            Amiga Build (europe)
                            by digi128pci
                            Hi all,
                            I was looking for a good speaker set for my TV setup ( I have a 2.1 setup Onkyo LS 3100 ATM).
                            First I was thinking about a bookshelf speaker like setup.
                            I found the site of Paul Carmod and found some designs that looked fine, but also noticed the amiga....
                            03 May 2014, 15:56 Saturday
                          • Preacher
                            Basic 2way options
                            by Preacher
                            After Much searching and learning my ambition has been deflated a bit.
                            All I want now is a good 2way for reference and basic listening pleasure. My Ht room is sub-optimal so great performance HT system is lost on me to a degree.
                            I've got a Polk setup right now (M30/ Cs1)...
                            13 December 2007, 12:47 Thursday
                          • jbruns
                            NewB working on Noobster 2way
                            by jbruns
                            Hi All,
                            This is my first post here... I have been troll'n around here for a while now, just learning. Played around with building some boxes in teenage years (for cars) but now I am bringing it back and moved to the home theater. This is my thead for my first project. The Noobster.
                            29 August 2008, 03:48 Friday
                          • Nordskov
                            Another Finalists build
                            by Nordskov
                            Hi everybody.
                            I am about to start building a pair of Finalists by Jim Holtz and Curt Cambell.
                            I currently run a pair of Dali Evidence 370 in which Im not satisfied. Not much bass, scooped midrange and aggressive highs. Actually I only run one as my son blew a woofer at a party this...
                            14 August 2016, 16:41 Sunday
