Does anyone know of a good speaker veneering tutorial video?
Not really needed. Just do a search here and read our tips/procedures. For confidence building, make a small MDF box and buy a very small amount of veneer at a local Woodcraft store and go for it. You can do it. As Jon/Yoda would say: "Do, you will"
Or something like that.- Bottom
This one is pretty much a waste of time. I think this guy just wants to be seen.
Veneering with yellow glue.
I plan on using the wood glue and iron technique when I veneer my next pair of speakers. It's got a pretty good following.-Josh
That feeling when things are finally going right. Yeah, that one.- Bottom
Advanced disclosure - I'm the author.
I recall a few years ago that there were some threads about "Why didn't woodworking magazines feature speaker-building stories?"
Now they have.
Woodcraft magazine took a chance. The October/November 2016 issue...-
Channel: Mission Possible DIY
by 123ToidI have a living room that had a really cheap Samsung sound bar that we picked up with a gift card a few years back. But I have always wanted to design and build a soundbar from scratch. So recently I did just that.
Goal: Is to have a soundbar that sounds great and is compact for most...-
by meb46Hello all,
I am about 25% of the way trhough applying veneer to some large cabinets and I have noticed a couple of defects.
The cabinets are MDT with curved Plywood sides. On the edges of the plywood where the veneer is applied to, it seems to dry and seal un-evenly to...-
by KennyBradleyHello,
I am about to start my first speaker project and have been researching veneering methods. Unfortunately I have not been able to come to any conclusions on the best method. My concerns are not just ease of use but I also want to ensure it will stand the test of time. I will be using...-
Channel: Woodworking tools & techniques
by snmhansonI am veneering my Statement Monitor and 2RCC build and have a questions. I am using contact cement based on the recommendation of the shop that sold me the veneer. It is all going reasonably well, except that I am getting a little lifting on some of the corners. It's not major, just a little at a...-
- Loading...
- No more items.
