Hello all,
I am about 25% of the way trhough applying veneer to some large cabinets and I have noticed a couple of defects.
The cabinets are MDT with curved Plywood sides. On the edges of the plywood where the veneer is applied to, it seems to dry and seal un-evenly to the plywood cut end. i.e. you can see faint lines of the individual ply's on the veneer. The veneer is 0.3mm Maple, and these can be sanded away but i am concerned I am going to sand through the veneer. The application onto the flat MDF is really good, but then the plywood is not perfect. I am using the iron on veneer method with pretty good success except for this issue.
It is possible to seal the ends of the plywood before veneering to stop this effect? Before application the ends are sanded and filled etc and the imperfections that appear after veneering are not seen pre-veneering.
Anyone with some suggestions or advice? Can I paint on an undercoat/sealer first, and then still adhere the venner to the sealer? Will standard white glue work for this?
