Question about resitances in inductors.
  • numberoneoppa
    • 535
    I am shopping for some Inductors right now and cannot find exactly what I need. The kit is Brian Powers's North Seas.
    According to the schematic, I need:
    Two 1.8mH / 1ohm inductors
    Two .15mH / .23ohm inductors
    This is what I've found:
    1.8mH - 0.47ohms DCR
    0.15mH - 0.10 ohms DCR
    Can I add resistors in series to make up for the lack of resistance in the schematic or is this trivial?
    Thanks!
    ps: If you have any cheaper recommendations, I'm happy to hear those, too!
    Last edited by theSven; 27 June 2023, 20:08 Tuesday. Reason: Update image location
    -Josh
  • Curt C
    • 792
    I'm sure Brian has the definitive answer, but it looks to me like air core Jantzens should work: 18 ga for the 1.8 mH, and the Jantzen 20 ga for the .15 mH.
    0.74 and 0.23 ohms respectively, and available at PE.
    Curt's Speaker Design Works
    • numberoneoppa
      • 535
      Thanks a lot! I didn't look at PE, but I guess that takes a lot of the headache out. I'm going to pull the trigger on these now, and if I need to in the future, I can make changes if I get an answer from Brian (not building for another month).
      -Josh
      • brianpowers27
        • Feb 2009
        • 221
        I used air core but you certainly could try it with iron core. The difference in resistance will affect the tweeter to woofer balance a little. You could adjust the series resistor from 2.7 ohms to a lower value depending on taste. It's likely I used 20 gauge inductors for the original spec. I likely guesstimated the resistance.
        Keep in mind that you are building version 1 of the xo. Version 2 is posted below. I'm not going to do a diagram but the layout should be fairly straight forward.
        --My Speaker building pages http://sites.google.com/site/brianpowers27speakers/
        --Get yourself on this forum member map! This can help everyone find fellow DIYers in the area.
        --The Speaker DIY resource Database
        • numberoneoppa
          • 535
          Thanks for responding.
          Actually, I saw version 2 last night about an hour after I ordered the parts for the first design. :P
          I'll stick with v1, for now. In your listening, how does v2 stack up against it?
          edit: Also, what are you using to drive the North Seas?
          -Josh
          • JonW
            What are your favorite low volume (small) inductors and caps?
            by JonW
            Hi Folks,
            After a long time away from speaker building (I had a kid), I’m getting back into it. The current project is a quite small speaker, with an internal volume of only 5 liters. I’ll start another thread on the design and goals after things are farther along.
            Due...
            14 February 2013, 10:34 Thursday
          • MrKazador
            Schematic help
            by MrKazador
            So I was lurking and came across a schematic I don't understand.
            I don't know where the positive and negative terminals would go(source). Usually I would see a ground symbol(negative) and signal generator(positive). This schematic has a circle with 2 lines coming out for...
            14 July 2010, 19:19 Wednesday
          • Amphiprion
            Help needed finding power inductors for PWM amp
            by Amphiprion
            I know we have some SMPS guys on the forum. I'm having trouble finding/selecting inductors for a Class D amplifier. Switching frequency is 384kHz with about 95% modulation range, 100W 8ohm / 200W 4ohm desired; values are 10, 15, and 22uH shielded ferrite inductors needed for 4/6/8 ohm applications (BTL...
            20 January 2009, 18:37 Tuesday
          • crisscross
            Mark's ER18 build- help needed with inductors
            by crisscross
            Hey guys,
            Re this thread last December, It took me 8 months to get the drivers and crossover parts for my build and I am finally ready to build!
            The only thing missing is the Inductors, the weight of the Inductors made shipping prohibitively expensive (I live in India)...
            25 August 2010, 22:29 Wednesday
          • ligonk
            Issues with C-Coil inductors from Jantzen
            by ligonk
            I am using some C-Coil inductors from Jantzen for my Modula TMM build. Them, along with every other inductor and part get measured prior to using them in my crossover. Every other inductor i have measured in the past ends up being ever so slightly above the stated inductance, which is great because...
            16 August 2014, 23:20 Saturday
