Cabinet Design Software
  • kirknelson
    • 89
    I'm looking for software to design speaker cabinets and furniture and am hoping there is something out there that is relatively cheap and easy to use.
    I can't really afford, or justify the cost of, expensive CAD software and I think there must be something out there for woodworkers that would work just as well.
    I'm sure some one here can point me in the right direction. :T
    Thanks!
    • kirknelson
      • 89
      Thanks Thomas. It's not exactly what I was hoping for but it will get me close enough for my purposes. The price is definitely right. :W
      • DancesWithBeers
        • 67
        The internet's leading online resource for learning Sketchup that is built and run by woodworkers for woodworkers.
        -DWB
        • Piotr
          • 102
          Go to products/downloads and click on The edge! :-)
          /Peter
          • Dave Bullet
            • 476
            Once you've designed your cabinet, download this nifty little program to organise your cut pieces from stock (minimise wastage, allowing for blade thickness in cuts etc...)
            • crazyjpeters
              Design goals
              by crazyjpeters
              I think I understand manipulating box parameters a little bit at this point, but I'm hoping some of the more experienced folks can shed some light here.
              Generally, increasing box size results in lower frequencies reached, with some tradeoffs, correct?
              Ideally, one would...
              08 September 2009, 21:03 Tuesday
            • kirknelson
              First Design: Advice please
              by kirknelson
              As the title indicates, this will be my first ever original design.
              I have some experience building speakers as I've built NatPs, Khanspires and the matching WTMW center.
              However, I have no experience with doing this from scratch so I will definitely need some help with driver...
              30 December 2013, 03:54 Monday
              2015 Burning Amp International Loudspeaker Crossover Design Contest
              Announcing the 2015 Burning Amp International Loudspeaker Crossover Design Contest!
              Your goal is to design a passive or active crossover for a 2-way mini-monitor using any freeware design software. The winning design will be awarded the drivers and cabinet for the project - design the best...
              16 September 2015, 18:24 Wednesday
            • xyrium
              Software to estimate F3 in ZRT design
              by xyrium
              Hi All,
              I'm considering doing a 2 way ZRT in a sealed cabinet. What I'd really like to achieve is an F3 about about 50hz. Is there software/freeware out there that I can use to estimate what the F3 would be for this design in a 20 and 30l cabinet?
              Also, if the sealed design...
              03 December 2009, 21:18 Thursday
            • ibilisi
              Questions RE front 3 for cabinet
              by ibilisi
              Hello all, I was hoping you could help with something. My friend recently purchased a pretty nice DLP TV (panny 50) and is currently refinishing his basement. His mother is a woodworker and is finishing a new cabinet for him in cherry for the new basement. This friend and I built a couple pairs of...
              13 March 2005, 01:47 Sunday
