Veneer edge banding on a rounded edge?
  • FroDaddy
    • 274
    I'm looking at the price between birch laminated ply from home depot versus buying veneer to laminate a large piece of MDF, and the ply is cheaper. I've used the birch laminated ply before on an entertainment system and the results were satisfactory. I used some composite plastic edging for the entertainment system, so I haven't used veneer edge banding yet.
    The speakers will have a painted black center, while the sides will be stained laminate. So the top, bottom, front, back of the speaker will be made first out of MDF and painted black. The sides will be made separately out of birch laminated ply, and will sandwich the MDF once completed. So, if you're looking at the front baffle you will have a painted black center with stained wood sandwiching it.
    This means that the edges of the ply will be exposed all around, which is where the edge banding comes in. That normally wouldn't be a problem, but the front of the speakers require a vertical roundover. So how realistic is it for veneer edge banding to be installed on a rounded edge? How about the "joint" between the ply veneer and the edge veneer?
  • David_D
    • 197
    My experience is limited but, from an engineering aspect, I think you would find it difficult to bond 1" wide edging around a 3/4" radius even if the veneer grain is going in the correct direction. Maybe with a vacuum press. My opinion is you may be better off jointing in a 3/4" solid Quater Round or If you have a nice tight lamiate ply, It may make some nice patterning with a round over cut right into the edge.
    My $0.02
    -David
    -David
    As we try and consider
    • Martyn
      • 380
      I agree with David. Instead of a vacuum press, you could make an edge-clamp by routing a 3/4"cove into a piece of wood, but by the time you've allowed for the thickness of the edge-banding and figured out how to deal with the joins, you could have glued solid birch along each edge, flush-trimmed it, and then rounded it over. Quicker, easier, a better job, and one that will never come unstuck!
      • tktran
        Veneering rounded edges
        by tktran
        I've had excellent results in the past with applying timber veneer on MDF, Pete Mazz style (coat veneer and substrate with PVA glue, and wait approx half hour til dry, then align, apply pressure and iron on) but always on a loudspeaker cabinet with square edges. This has worked great...
        26 June 2007, 10:23 Tuesday
      • goskers
        Veneer Problems
        by goskers
        Hello all,
        I have run into a problem with some veneer. I used the PVA glue method for the first time because I used a non-backed, quilted maple and didn't want to take the chance of contact cement bleeding through.
        After applying what I thought was decent amount of Titebond...
        10 September 2008, 18:31 Wednesday
      • esaleris
        Repairing Tiny Chip in Wenge Veneer
        by esaleris
        In an unfortunate incident last night, I stepped on a level I was using to level off my audio rack, slipped on it, and shot it straight into my CM7s in Wenge.
        First, I'd like to say that the guys are really sturdy - even though the level went straight into the speaker, the only visible...
        24 March 2009, 08:56 Tuesday
      • kirknelson
        A few finishing questions (Veneer)
        by kirknelson
        I'm about to begin building a pair of NatPs which will eventually be used as surrounds with a the Khanspires/Khancenter. I plan to paint the baffles black and veneer the remaining 5 sides. This will be my first attempt at veneering a project and I have a few questions before I begin.
        22 March 2009, 07:55 Sunday
      • JonP
        Ironing on Veneer question
        by JonP
        Finally, a 3 day weekend, and one not totally occupied with other commitments...
        Hoping there's a few iron on veterans out there. I know Jon was doing some long pressing with the M8ta's....
        I got myself some nice African Mahogony veneer, and I'm planning on the iron on-yellow...
        25 May 2007, 13:32 Friday
