Need a replacement for 12" Assassin. Any Ideas
  • dawg1161
    • 238
    Hello everyone, Not long ago i built a sonosub for a 12" Assassin. I hve since built 2 more 12" Assassin's in 18" sonotube. My problem is i can't find another 12" Assassin to go into a 16" sonosub 6.8cft volume with a 6" 23" long port tuned to 21hz i believe. so i have this empty sonosub sitting around and would like to get some ideas for another sub to put into it. Would like to keep it under 125$..........Any Ideas ?
    http://www.tcsounds.com/db500.htm
    • dawg1161
      • 238
      Thanks Thomas, would this sub model well in my enclosure Ed Ehqs 12" ?
        As far as I'm concerned a poly cone driver with 9mm of Xmax, a 25.5Hz Fs, and 50 mm VC is a woofer not a subwoofer.
        • dawg1161
          • 238
          That takes care of that one then....If i use the db-500 i'll have to enlarge the cutout for the subwoofer..............I'll look at some more subs with the same cutout hole size.
            Whats wrong with enlarging the cutout?
            • dawg1161
              • 238
              Nothing , its just a pain to mess with (this sonosub is 67" total height)
