Hello everyone, I'm on a mission to build my first Dual Sonosub. Actually I have two JBL GT1000D 10" DVC Car Audio Subwoofers that I would like to put to use in the dual sonosubs. The drivers are pretty robust with nice size magnets, motor structure, and weight. Below you'll find the drivers information.
JBL GT1000D
10” Component Low - Frequency Transducer
2” Dual - voice coil
I-beam basket
Specially treated pulp woofer cone
Sensitivity: 94dB (2.83/1volt)
Freq Response: 30Hz – 3.5kHz
2 or 8 Ohms depending on system wiring
Hi-roll rubber surround
Recommended power amplifier range:18W-275W
Mounting depth: 5-1/8”
I dont know the Thiel/Small Parameters. Anyone know where I can find this info for this driver?
I would like to get some input as to the proper design of the sonotube length, and diameter, port tuning, and size, as well as input about proper system integration.
First for the sonotube length and diameter. I like the size of the SVS 16-46PCi Subwoofers for their extension, and size. They are 16" in diameter, 46" tall, and are tuned to 16hz. I would like my sonosub to mimick this performance as much possible for a 10" DVC.
My goal for this project is for my sonosubs to take over where my mains lose steam. My main speakers are Definitive Technology BP2006TL's and a C/L/R 2300 Center Channel. The BP2006TL's are -3 down at 33hz, and -6 at 31hz. I would like my subwoofers to come in and take over below 33 hz and extend down as low as possible.
Next is port size, and tuning, I need to know how I can find the diameter of the port and length.
In the materials area, I plan to use the most economical materials I can. I plan to either have a friends father use his companies C-N-C machine mill the end caps out of 1" MDF. I plan to use 1 ply of 1" MDF for the end caps, meaning no gluing two pieces of 3/4" MDF together. I would like the woofer mounted on the bottom to avoid tipping, as I have a cat, and daughter. I will be finishing the end caps in gloss black paint, and the rest of the tube in speaker fabric. So as to match my mains which are finished in the same way.
What is the best, most economical, and easiest way to secure the end caps to the sonotube?
This is my first sonosub project, however it is my 4th speakers project. And probably the easiest as far as design, complexity of the entire project goes of the 4 that I have done previously. For this project, the only real restrictions I have are economics, sonotube diameter (not more than 16"), due to placement issues in my room.
I plan to use a Nady XA-1100 1100 Watt Power Amplifier to drive both subwoofers. Since the JBL's are DVC I would like to use both voice coils and drivet he amplifier with more power, at a lower impedence.
Any help with this project would be appreciated. Along time ago, when I planning this project, I ran across a little software program that you could enter the frequency you wanted the system to extend down to, the driver size, etc, and it would spit out the sonotube size, lenght, port diameter, and length, etc. Anyone know of this program. It isnt one of the large speaker building programs like Speaker Easy, etc., it is specifically designed for sonosub's. It was quite useful.
JBL GT1000D
I-beam basket
- Threaded Rod
- Screws into the side of the Sonotube into the MDF.
- Silicone
