Sonotube Sub questions
  • Johnny5
    • Feb 2007
    First off I'm new here to the forum. And I've become interested in making a DIY Sonotube sub. I get the concept of how the sub is built but I have a few questions about a couple of things mainly how to get a correct volume for the tube. I've punched some numbers into a few different programs WinIsd Beta and the Pro Alpha, and Unibox but I'm not really sure what volume of tube I need. I was shooting to find possibly a 24" wide tube to eliminate the height of the tube . The driver I'm interested in using is the DAYTON RSS390HF-4 15" HIGH FIDELITY from PE. The T/S parameters are Specifications: *Power handling: 500 watts RMS/800 watts max *VCdia: 2-1/2" *Le: 1.00 mH *Impedance: 4 ohms *Re: 3.3 ohms *Frequency range: 18 - 800 Hz *Fs: 18 Hz *Magnet weight: 150 oz. *SPL: 90 dB 2.83 V/1m *Vas: 9.55 cu. ft. *Qms: 3.10 *Qes: .49 *Qts: .42 *Xmax: 14mm *Dimensions: A: 15-5/16", B: 14-1/8", C: 6-1/8".
    According to WinIsd Beta to tune the box to 17 Hz I need a volume of 18850.2 cubic inches or 308.9 l's with a 6" port 18.5" long
    According to WinIsd Alpha to get 17 Hz I need a volume of 648.4 l's with a 6" port and 7.07" long.
    I might be punching in some numbers wrong. Thats one of the reasons that I came here because I've been reading a lot of the DIY threads and seen the knowledge that is being shared on the forums and figured this is the place I need to be.
    And the second question is what power from an amp should I go for? I was thinking about using a power amp instead of a plate amp. I didn't know if I should match up the power to the RMS value or the Peak Power handling value. I plan on starting the project early summer maybe late spring, right now I am just doing some planning ahead so i know what to expect material wise when I go out and start my project. Thanks in advance for your input and advice
    John
  • Gir
    • 309
    I'll be building a sonosub in the coming months with the exact same driver. I'm going to use a 410 liter enclosure and tune it to ~13hz. For a 17hz tune you should be fine with around 300 liter. With WinISD just play around with the volume size and tuning point and see how it changes the graph.
    -Tyler
      Sorry to say but PE doesn't not recommend horizontal mounting for the RSS390HF
      This is a good driver if you want something downfiring
      http://www.tcsounds.com/tc1000.htm
      Delete WinISD beta from your PC because it's not accurate. WinISD pro or Unibox (recommended) are accurate.
      There's nothing gained by using a 6" port with a modest excursion 12" driver, a 4" flared port will work fine.
      • Johnny5
        • Feb 2007
        Thanks for the quick response's. Thanks Thomas for saving me from a potential problem with mounting the driver horizontally. When figuring out the volume do i have to add in for the space that the port is taking up or does that matter at all?
        • WillyD
          • 675
          What Thomas said...and the 15" TC-1000 will be released in the next 5-7 days.
          You must take the volume taken up by the port into consideration, yes.
          • cjsmith
            Advice on sonotube with a 15" PPI car sub?
            by cjsmith
            I've been reading about the sonotube subs, and I'm wondering if I could build one with a sub that I have lying around. This is an older car audio sub - Precision Power (PPI) Pro 15, flat piston. T/S, that I found from WinISD, are posted below.
            One of my concerns is Fs. After plugging...
            24 November 2006, 19:53 Friday
          • TG284
            General Sonotube & Tempest Q's
            by TG284
            For the last month or so it seems as if I’ve read an infinite number of build threads, personal sono pages, and been tinkering with sonosub.exe/winISD… I planned to simply copy another person’s design, but am still a bit short on some basic knowledge…
            Quick sum-up, plan to...
            13 January 2010, 15:48 Wednesday
          • HMenke
            Sanity check sonotube sub DIY project
            by HMenke
            First time post here after lurking and discovering that this is the ultimate DIY forum on the web! :T
            I recently acquired a BFD1124P and RoomEQ Wizard. Result: instant dissatisfaction with my old Paradigm PS-1000 10" ported box subwoofer. Output rolling off steeply below 35 Hz...
            26 February 2006, 13:09 Sunday
          • xLoSx
            New member and new sonotube!
            by xLoSx
            Well after reading straight for about a week I have decided on the type of sub I want to go with... and it is a sonotube sub..
            I will either be using a 15" tempest from adire or a soundsplinter rl-p15 from tc
            I had a few hard size limits and those were 60" tall...
            23 March 2006, 00:43 Thursday
          • v8lifestyle
            NEWB WinISD question
            by v8lifestyle
            I searched and looked for 20 min and couldn't find an answer so sorry about the super basic question. Anyway my question is when entering the box volume, I just enter the volume of the enclosure as if there was no port installed. Correct? Its a ported design BTW. I am using 24" sonotube that is...
            05 October 2006, 13:53 Thursday
