Interesting and Inexpensive Wave Guide
  • Spanky Ham
    • 88
    Thylantyr pointed out the Elsinore speaker over on AVS. It uses a wave guide that he calls a diffraction wedge. I thought it was a unique way of making a wave guide. Any thoughts?
    Last edited by theSven; 15 December 2024, 09:53 Sunday. Reason: Update links and image location
    • 16202
    This is a somewhat primitive approach to a waveguide, I would like to see what the off axis plots look like- that he lines this with felt to kill reflections gives some hints about issues with the behavior.
    But a lot of thought and effort obviously went into this, it's just frustrating to read considering the information he's left out so far...
    I think the appellation "diffraction wedge" may be much more appropriate than waveguide. What I would want to see is a series of on axis and off axis plots (horizontally and vertically, since it's not symmetric) similar to those posted by others for various driver/waveguide combinations, or like the plots I took last weekend for the BMS4540 and DDS ENG-1.
    This is the raw response, before shaping by the crossover; in this case, the target would be additional attenuation below 10 kHz of the driver level, some shaping at 2 kHz, then a steep crossover around 1.8 kHz.
    These curves were taken between 0 and 45 deegrees off axis; at the outside range of the waveguide, not that the basic FR profile remains largely the same, just the level drops going off axis.
    Last edited by theSven; 15 December 2024, 09:50 Sunday. Reason: Update image location
    • JoshK
      • 748
      if one wanted to get creative, instead of a pyramid like waveguide with four sides, you could add additional sides, 8, 16, 32, .... estimating a cone with successively smaller and smaller sides...kinda like calculus. Might be more work than its worth though.
      • timber_mg
        • Jan 2007
        • 30
        Well it's kinda like adding foam to the sides of a B&W tweeter to make it palatable in anything other than the deadest of rooms. He will suffer a bit of diffraction at the transition but otherwise it may well be an improvement above just a normal tweeter.
        • SpinMonster
          An active TMM wave guide speaker
          by SpinMonster
          I’ll start this off by saying that I will never build another system without a wave guide. If there are any downsides, I don’t see them.
          This system uses 2 RS180 midbass and one XT25tg60 (double magnet) in a wave guide crossed actively at 1700hz. The XT25/60 is superior to the single...
          16 September 2013, 10:36 Monday
          Driver Evaluations for a new project
          by Evil Twin
          Working from the top down, starting with the treble unit.
          Not to be compared with any other specific tests; all testing conducted on a finite baffle; 9" wide, 22" tall, rounded edges; representative of somewhat typical enclosure dimensions.
          Curves taken on axis, 15...
          27 April 2009, 22:26 Monday
          Simple DIYable Waveguide testing (dome tweeters)
          by dlneubec
          Hi All,
          I have been doing some testing with shallow waveguides for my BaSSlines project that I thought you all might be interested in. I posted this in my BaSSlines thread, but realized many of you who might be interested could miss it there. I created an insert into the baffle that would...
          13 October 2008, 16:41 Monday
        • mdrake
          Need help finding a wave guide and compression driver
          by mdrake
          I need some help finding a replacement wave guide and compression driver to replace my Selenium ti and parts-express 10inch waveguide.
          I think I have narrowed it down to one brand of compression driver and two wave guides but if there are better options I would love to hear them. I am...
          12 April 2010, 10:48 Monday
          by ---k---
