I've had my eye on the Usher 8137a driver for a while now, but haven't seen it used much. Talk about low distortion...
Since the 8137a compares favorably versus even the 8945P (a driver which Zaph recently measured with similar results as shown by mfg specs) in terms of distortion by Usher's spec, I'm guessing Zaph would see the same results.
Difficulty with the 8137a: Qts of .45ish and VAS of 60L make for a largish (tho not inconceivable) vented box. Also, with FR nastiness starting ~1100 hz, conventional crossovers are a pain, and pretty much limits it to 3 way use.
Unless....
You use something like the BG NEO8. Yet another driver I haven't seen used. Not the flattest response, but it opens up all sorts of possibilities being able to cross as low as 600 to 700 hz, especially if you're thinking two way. And being a purely resistive load makes it easy on amps.
Difficulty with BG NEO8 PDR: Not a flat response (requires a notch filter at 12khz), must tune the enclosure right to get the extended midrange response, doesn't have an extended high end.
With these drivers in mind, anybody think its possible to pull off a 2.5 way tower, maybe 100L vented to 32 hz or so, crossed at 900hz? The BG NEO 8 is a big question mark to me. Has anybody actually heard it in action?
I think with some care it could be done. Any thoughts?
~Sam S.
Unless....
~Sam S.
