Wiring up two 8ohm drivers for bookshelves.
  • Rufes1
    Hey all,
    Well this is my first post here so a hello to everyone.
    I have the 2 perfect drivers to use in my new bookshelves. Problem is I want the total impedance to be 8ohm, but the impedance of each driver is 8ohm.
    So in series its 4, parallel; 16.
    Now what I wanted to know is how much power I am going to be loosing if I run them at 16ohm? I suspect there is a formula in the theory of maximum power transfer to work out exactly how much I am loosing? I couldnt find much..
    Secondly.. Is there any way to wire them in parallel and then add a resistor either in series or parallel to alter my total impedance/resistance? Or will this consume too much power?
    Thanks again
    A resistor will get 1/2 the power so that's not a good thing to do.
    Actually you don't loose any power with a 16 ohm load, the amp simply won't make as much with that load.
    • Karma
      • 801
      HI Rufies,
      I think you have the formulas for equivalent resistance in networks reversed. Equivalent resistance for parallel resistance is always less than the lowest value resister. In your case its 8 ohms in parallel with 8 ohms for a value of 4 ohms.
      Series resistances add so in your case it's 8 ohms + 8 ohms equals 16 ohms.
      Actually, resistors are used very often in crossovers to balance both impedance and unequal driver sensitivity. They are one of the very few tools you have available to do this. And yes, they can waste power which must be considered when specifying overall speaker sensitivity.
      Sparky
      • Rufes1
        Hmmmm
        yeh your right.. A resistor would just be a waste whichever way you look at it.
        Next question, say I my amp pumps out 80wrms per chan at 8ohm. How would I figure out how much it is going to pump out at 16ohm?
        • ruseriousclark
          Measuring Resistance issues
          by ruseriousclark
          Three 8 Ohm drivers in parallel should yield a resistance of 2.667 Ohms. However I just wired it up and threw on the meter and cannot get anything other than 3.4-5 Ohms as a reading.
          Busted meter or is my math just that bad?
          FYI... 3 M3N's wired in parallel
          29 January 2011, 22:50 Saturday
        • juliovideo
          Two woofers ?
          by juliovideo
          I can connect two woofers in series of 8 ohms and a resistance in parallel for 8 ohms total take. ?
          I would have that problem in this design?
          thank you.
          27 April 2009, 13:31 Monday
        • Gump
          Value of an amp doubling wpc 8ohm vs 4ohm
          by Gump
          I know this has been discussed before but I did a search and it's a hard subject to explain to a computer because I couldn't find anything.
          How important is it for an amp's wpc to double from 8ohm's to 4 ohm's? Is it really that big of a deal? And I'm talking pure SQ here.
          13 April 2006, 01:52 Thursday
        • spadez
          Wire and resistance question for Dayton RS TMWW
          by spadez
          I am in the process of finishing up some speakers and I was wondering if anyone in the know could help me out. It is mostly to do with cabling and resistance.
          My first question is, what overall resistance is this speaker, the Dayton RS TMWW. Is it 4ohm or 8ohm overall?...
          04 March 2013, 09:29 Monday
        • augerpro
          Resistance effects on Q
          by augerpro
          I did a little experiment to see how changing resistance changes driver Qts. I thought some of my fellow newbs might find it interesting. I used teh RS150.
          RS150 Nominal Qts= .4947
          RS150 8 Ohm in series (16 Ohm nominal) Qts= .9122
          RS150 8 ohm parallel (4...
          18 May 2007, 16:51 Friday
