10 Hz filter for sealed sub?
  • kramskoi
    • 59
    Hoping not to defeat the purpose of a sealed 2nd order roll-off transducer, i'm in search of a 10 Hz butterworth filter with a 12db/oct. slope.
    I'm planning on a sealed 15" Tumult DIY sub...L/T'd with an adire ada-1200(watt) amp.
    I've spoken with Brian Bunge and he has assured me of the tenacity of the Tumult driver but i'd like a little protection anyway.
    I would prefer a passive inline design, but i'm not opposed to an active solution (if it's cost effective).
    Any one with some expertise in this area is welcome to chime in...Thanks :T
    ...our brains and nervous systems constitute a belief-generating machine, a system that evolved to assure not truth, logic, and reason, but survival...
    2x15" TC Sounds .45Q sealed
    M. Boutte HT
    3x15" @ 10 Hz
  • wildfire99
    • Aug 2005
    • 257
    I'd think this would help with power output and sound quality also during really brutal (read: War of the Worlds DVD) playback.
    - Patrick
    • David G
      • 170
      Check these links:
      or
      electronic crossover, analog crossover, active crossover, discrete crossover, internally balanced, tube crossover, valve crossover, tube analog crossover
      The 24dB Marchand crossovers are easily configurable for 12dB.
      Have you done a WinISD/Unibox simulation to determine your power handling?
        12dB passive filters are a bit tricky because of insertion losses and their dependance on the input impedance of the amp. The Furman Q-1311 EQ has a 10 Hz active 12dB filter for about $70 and it also does 1/3 octave graphic EQ.
        Get the guaranteed best price on Specialty Bass Pickups like the Basslines SRB-1 Pickup for Rickenbacker Bass at Musician's Friend. Get a low price and free shipping on thousands of items.
        • Mark Seaton
          • Aug 2001
          • 197
          Psst... if you really want to add this filter, just mod the one built into the ADA amps which is normally at 2Hz with a Q of 0.5.
          Mark Seaton
          • Exocer
            Planning 3.5ft^3 sealed Tumult D2
            by Exocer
            Well, got a good deal on a Tumult driver. I am not looking for major SPL but am looking for some sort of flexibility and possibly a subsonic filter to help reduce Tinsel slapping issues...
            The Oaudio 500watt bash looks good with its adjustable subsonic filter @ $240
            The PE 500watt...
            20 July 2006, 23:16 Thursday
          • kramskoi
            my Tumult...depressed at 22 Hz
            by kramskoi
            I would welcome any observations and tips on the following dilemma at 22 Hz:
            I've tried moving the sub up, down, backwards, forwards and every which way and the null remains. I've done manual sine wave sweeps with the same result. This sweep
            12 March 2006, 21:18 Sunday
          • Jose_L
            Can a sealed DIY sub beat a Servo 15 ?
            by Jose_L
            Hi everyone,
            I'm looking for opinions if it's worth building a sealed sub that will beat the performance of a Paradigm Servo15 sub.
            I've chosen a Ada1200w plate amp $600 and would build a 5^ft enclosure.
            Now I'm looking at the AV15 $180, SS RL-p15d2 $269,...
            21 March 2006, 16:28 Tuesday
          • kgveteran
            12db/oct line level filter
            by kgveteran
            What are your thoughts on this.My subs are xover at 80hz.The processor does this electronically @ 24db/oct.
            My mains are also xover via the processor at 80hz , but at 12db/oct. Is it possible to get a line level 80hz 12db/oct filter to add to the one that is already in the processor ?...
            14 January 2006, 22:36 Saturday
          • kramskoi
            xmax vs. xlim for the tumult?
            by kramskoi
            Does anyone happen to know what the xlim is on the Tumult 15" driver. I know xmax is 33-34 mm but perhaps someone "in the know" can tell me if there is more to the mechanical limits of this driver.
            I read a post on one of the home theater forums by Dan Wiggins which goes...
            11 January 2006, 09:16 Wednesday
