Recommended sealed volume for Dayton RS315HF?
  • silvercans
    • 39
    I was messing around with some modeling software for my Dayton RS315HF and to my surprise it came back with a recommended sealed volume of 1.268 cf with some fill (F3 was 41 HZ). Does this sound right? From what I read on the forum it seems people are recommending much bigger volumes. What do you recommend? Thanks
    Much bigger. Going back to SL's spreadsheet, box air-spring distortion is proportional to 1/box size.
    (air spring distortion %) = 140 * (one way driver displacement) / (box volume)
    Edit: that's my theory about why an IB sounds better than a sealed box. The air spring distortion is zero for the IB.
    • silvercans
      • 39
      Thanks for the response. Could you recommend any IB designs using two RS315HF's?
      Anyone else? I'm still curious to know what you recommend for a sealed volume.
      • silvercans
        • 39
        no one? how about 2cf sealed?
          To model an IB, just enter 10,000 liters as the box volume in your software sim for a sealed box.
            Dennis,
            He's confusing 'true' IB with acoustic suspension/ small sealed box.
            • silvercans
              • 39
              No I completely understand Dennis' recommendation for an IB. However, I may not go that route and needed to know what some would use if they had to choose sealed.
              • jkrutke
                • 590
                RSS315HF Sub Design
                First post on this forum, I think. I just tried to post this on the PE forum and it puked on me.
                I used 2.0 cu ft sealed. Sounds very good. I'm very happy with this sub.
                Zaph|Audio
                  • 16175
                  Nice looking design, John, and thanks for posting a link to an archive zip. easier than downloading the web page itself to my HD (my usual tactic!)
                  A lot of people who don't usually like subs will like subs done with these Dayton RS series drivers. My theory about that is that the integration with whatever main system you use is better because of the low VC inductance (which means they don't start rolling off around 70-80 Hz like so many super long throw drivers), and the extended response to 200 HZ and beyond, as well as very stiff, rigid cones. I like your sealed design, and it's similar (in volume and concept) to something I'm considering for the bottom end of a floor standing speaker (a large floor standing speaker!).
                  Still more points to ponder, as it's intended for music mostly, I might go ported (tuned low with tapering response) or might go sealed for the reasons you give.
                  Happy New Year, and hope you drop by HT Guide from time to time.
                  ~Jon
                  • KeithM
                    • 285
                    With WinISD I'm it looks like 2 cubic feet would be good with an F3 around 46.5 hz.
                    • silvercans
                      • 39
                      That's interesting because the software I was using said a 2cf would yeild a F3 of ~40hz.
                      • Paul W
                        • Oct 2004
                        • 552
                        John,
                        Nice looking sub! Is the baffle paint or metal?
                        If you don't mind, would you send me the impedance file for that driver? Free air prefered but box okay. pnwright3@yahoo.com
                        Happy new year!
                        Paul
                        Paul
                        • jkrutke
                          • 590
                          The baffle is paint. It's Rustoleum Bright Coat Metallic Aluminum Finish #7715. When it's painted over two coats of textured enamel #7720, it looks exactly like an aluminum casting. Then for good measure I put a clear coat over that, and it's very durable. It's a great look that I'm going to start using more in the future. I think I like it more than any kind of wood, and it's much easier to do.
                          I don't actually have an impedance file. I got the T/S numbers a while back and they were dead nuts identical to the numbers posted at PE, even the Vas. No worries using PE's numbers. My impedance curve posted in the design is generated from the T/S numbers.
                          Zaph|Audio
                          • jkrutke
                            • 590
                            You make good points about the VC inductance. I also noted that this driver has less of a nasty peak/dip in it's upper response. (I did a quick full range impulse through the amp with the LFE input) It's not nearly as bad as a Peerless XLS. I've only done distortion tests on a few subs in my life, but this Dayton was overall cleaner than anything else to come through my house.
                            If I ever needed more output, I'd simply buy two of these rather than one of the "super-subs" out there.
                            My setup was for HT only. For music only, I would guess that vented would be acceptable too. Less chance of a stray 15hz coming through and bottoming the sub out. :B
                            Zaph|Audio
                            • Paul W
                              • Oct 2004
                              • 552
                              John,
                              Couldn't tell if it was paint or metal & thought my eyes were not good enough! Interesting finish...I'll try it sometime.
                              I'm not so interested in T/S parameters as glitches & wiggles in the impedance curve to get an idea of how high it can go before the nastys set in. I'll take anything ya got in that area!
                              Paul
                              Paul
                              • sfdoddsy
                                My cunning new plan: RS315HF & DPL12 swap
                                by sfdoddsy
                                I've been looking at building a smallish sealed sub to use below 40Hz with my dipoles. The RS315HF was a candidate, but the box models little small for it in Unibox.
                                Then it occurred to me that I have ideal drivers for this frequency range in my dipoles - the Adire DPL12. And that the...
                                22 September 2009, 00:37 Tuesday
                              • Cameraman
                                internal volume for Aurasound NS12-794-4A 12" sealed ?
                                by Cameraman
                                I’m getting ready to build a sealed enclosure using an Aurasound NS12-794-4A 12" subwoofer and want to confirm the optimal internal volume for a sealed design. I will try some of the tools available but seem to have a compatiblity issue with office 2007.
                                Primary use is music and...
                                28 March 2009, 15:57 Saturday
                              • lcolbur1
                                Unibox Volume Calculation Question
                                by lcolbur1
                                Correct me if I'm wrong, but once I input the required driver specifications into Unibox, it calculates a recommended volume, be it for sealed, ported, etc. I'm assuming this volume is accurate, but based on what? I input Dayton's 5" reference driver specs and got a suggested volume of 2.6 liters...
                                06 May 2015, 15:24 Wednesday
                              • cdwitmer
                                Can I use short pipes to join two sealed subs into one?
                                by cdwitmer
                                I want to use two sealed subs side by side in a push-pull alignment to reduce distortion. To do that properly, I need to get the volume of the two subs the same, which is a bit of a pain since I don't have any good way of accurately measuring the displacement of the driver. Of course, if the two drivers...
                                30 April 2007, 10:03 Monday
                              • sisu
                                Solved: Tweeter distortion from my almost-finished Modula NeoD CC
                                by sisu
                                [Edit] The tweeter distortion problem was fixed by moving the RCA inputs to my receiver to the "CD" input, instead of the "Phono" input.
                                This is my first time with DIY speaker building, and I have quite enjoyed the ride.
                                After researching and talking about...
                                25 July 2009, 09:57 Saturday
