I’m getting ready to build a sealed enclosure using an Aurasound NS12-794-4A 12" subwoofer and want to confirm the optimal internal volume for a sealed design. I will try some of the tools available but seem to have a compatiblity issue with office 2007.
Primary use is music and secondary use home theater. I will get as much amplifier as needed so while efficiency is nice, performance is more important.
As an update I am finishing up a previous project and have one more coat of paint to put on the Aurasound NS10-513-4A 10" Sealed pair I am building before I install the drivers and fire them up.
Thank you.
From Madisound
Fs 27 Hz
Nominal Imp. 4 ohms
Power (RMS) 400 W
Re 3.5 ohms
Sens. 1W/1m 84 dB
X-max peak 18 mm
Qms 7.1
Qes 0.45
Qts 0.43
Vas 78 ltrs
BL 14 TM
Mms 152 gr
Cms 233 mM/N
Sd 487 cm2
Net weight 8.0 kg
Max Exc. p2p 60 mm
VC diameter 79.4 mm
Recommended Enclosure:
F3 of 25Hz: 3.5 cubic feet with 4" Ø vent by 12" long (But I want sealed)
Thank you.
From Madisound
Fs 27 Hz
Nominal Imp. 4 ohms
Power (RMS) 400 W
Re 3.5 ohms
Sens. 1W/1m 84 dB
X-max peak 18 mm
Qms 7.1
Qes 0.45
Qts 0.43
Vas 78 ltrs
BL 14 TM
Mms 152 gr
Cms 233 mM/N
Sd 487 cm2
Net weight 8.0 kg
Max Exc. p2p 60 mm
VC diameter 79.4 mm
