I've been modelling the new XXLS series to see which model would be a suitable replacement for the Dayton Audio 12" DVC (PE #295-185). It will be used in my current 1.5cu ft sealed cabinet and 250W (4ohm) plate amp with boost (v. similar to PE #300-796, boost settings are perhaps different)
I've simulated the XXLS 830845 (12", rec. for sealed cabinets) as well as the 830847 (12", dual 8ohm voice coils, with DST recommending a vented cabinet).
However, in the 1.5cu ft cabinet, the 830847 seems to model better than the 830845. I get a Qtc=1 for the 830845, but Q=0.75 for the 30847.
Can anyone here confirm/refute my simulations?
I use Subwoofer Designer 2, and the revelant files are at my website:
