Upgrading my amp to a ADA1200 for my brahma 15 (house)
  • Fox Hunter
    • 5
    I Have a brahma 15 mark II sub powerd by a cheap 360Watt Amp in a 7cu foot tuned to 18hz box. I have Adire ADA 1200 Amp coming and am building a 2cu foot seald box. Any thought on if this is to small, should i stuff it with polly? Will heat be a issue in the sealed box? I read that some of you keep the amp outside the box. Nice idea btw I already have the the cut out for the amp in the box but can alway close it up. The amp has a Linkwitz transformer on it to should I be doing anything with it or will it not make a larg diff.
    Any thoughts would be great
    The amp sould e here in a few days ill let you guys know how it turns out.
    Thanks for your time
  • Bent
    • Sep 2003
    • 1573
    Sorry if I mis-understand here,
    you say you have the L-T installed already without having measured the ADA 1200 driving it? I ask because I am under the impression that to utilize the L-T portion of the ADA 1200 (and all the ADA series, for that matter), that the driver should be tested in-box and the results used to determine the values of the components you install on the PCB pads that are in the ADA already. I guess there is a chance that you know the response characteristics of the driver as installed in your box already, and if that is the case, I must appologize. If not, then attempting to utillize the L-T provisions on the ADA (without thorough fore-thought) could result in damageing your driver.
    • Fox Hunter
      • 5
      No i dont have the ADA yet im trying to get some good info befor i get it. I know what the L-T dose but but no clue on setting it up right. Going to make sure I know what i'm doing befor i mess with it. (If i ever do) Any thoughts on the box size?
      Ty for the fast reply
      sub specs here
      http://www.adireaudio.com/Files/cut%...20Brochure.pdf
      • Fox Hunter
        Fried my Brahma last night need a new sub (house)
        by Fox Hunter
        First off i have 15" brahma mark II it in a 2^3 foot box powered with a ada1200. Just to much heat in a seald box i guess Insane amount of smoke when i pulled i t out. No recone kits available atm.
        Was looking at 15 tumult if they ever start shiping but probably cost close to...
        13 August 2005, 17:40 Saturday
      • Exocer
        Help me choose a 15" driver for my 110 liter box!
        by Exocer
        Hey guys,
        I have a sealed 110 liter box (thanks again steve), and an Ep1500 (on the way) screaming for a 15" driver. Some of the popular choices come to mind...SS Rl-P 15", Titanic 15" etc. I've gotten used to the low inductance of the Rythmik driver and am affraid i'll have to...
        15 August 2006, 22:39 Tuesday
      • Lurkalot
        Adire ADA1200 Query
        by Lurkalot
        I just had my ADA1200 repaired today at a cost of $168.00; the output transistors were all replaced. This amp literally had less than 3 hours of use on it before it quit working. I had turned it on the sixth time when I heard a small pop and it quit. The technician appeared less...
        16 June 2009, 23:28 Tuesday
      • Bent
        ADA 1200 rumble filter
        by Bent
        The folks at Adire tech support have indicated to me that my ADA 1200 sub amp is equiped with a rumble filter set at 1.8 Hz. They said that by paralleling a pair of 11k resistors in the R48 and R51 positions (which should be 100K in each, as per OEM spec) should result in the cut-off frequency coming...
        21 April 2005, 10:13 Thursday
      • kramskoi
        built-in LT circuit on the ADA-1200 amp?
        by kramskoi
        Anyone with experience using the built-in LT circuit on the ADA series amps by Adire Audio?
        I'm under the impression that this is a stuffing procedure as opposed to a soldering one. Is this correct?
        Are the resistors and capacitors supplied with the amps?
        02 February 2006, 21:30 Thursday
