Series woofer inductor Iron Core Vs Air Core
  • Jed
    • 3621
    What is the audible difference for large value inductors for a woofer in series with iron core or air core if both have the same DCR? Are saturation effects audible and when do they occur?
    Jed
    • 16163
    They occur under large signal conditions (high drive) where the current level starts to push the flux in the core near the limits of the BH curve for that core configuration. In mild cases, it increases the harmonic distortion due to the inductivity modulation with signal levels (as occurs in drivers themselves to varying degrees). In more extreme cases, a high bass transient may cause a sound almost like a cracking or thudding noise- I've heard that in some Legacy models demo'd at the factory- they use too many ferrite core inductors IMO. This was with a fairly high power amp (400W/ch)
    I have designed and used large transformer style inductors in the past, using silicon steel laminations, but these days I'm pretty much 100% air core. I get the big ones from North Creek, as my own coil winder in Denver won't really handle AWG 12 wire.
    ~Jon
    • TacoD
      • 1080
      I use iron core from Mundorf for large values >= 6,8 mH and up. I prefer those over ferrite core.
      • morbo
        • 152
        Jon what do you think of the Erse 'shaped core' inductors;
        Does the shaped core really help offset the iron-core disadvantages?
        • crisscross
          Mark's ER18 build- help needed with inductors
          by crisscross
          Hey guys,
          Re this thread last December, It took me 8 months to get the drivers and crossover parts for my build and I am finally ready to build!
          The only thing missing is the Inductors, the weight of the Inductors made shipping prohibitively expensive (I live in India)...
          25 August 2010, 22:29 Wednesday
        • JonW
          What are your favorite low volume (small) inductors and caps?
          by JonW
          Hi Folks,
          After a long time away from speaker building (I had a kid), I’m getting back into it. The current project is a quite small speaker, with an internal volume of only 5 liters. I’ll start another thread on the design and goals after things are farther along.
          Due...
          14 February 2013, 10:34 Thursday
        • spadez
          James' loudspeaker project thread
          by spadez
          I'm been following JonMarsh's Modula Xtreme progress for a while and its at the stage now where I want to start buying the components needed for the project.
          I'm a little new to this, so instead of clogging up Jon's thread, im going to post my questions here in the hope of getting these...
          17 June 2010, 12:54 Thursday
        • Warrant
          What's the difference? (Stealing an article series from Fine Homebuilding)
          by Warrant
          Crossover components.
          As I am gathering parts for my build(s) I see many items that have the same values but are different designs and price points. Resistors as an example, metal oxide or wire wound. Is one better than the other? Is it application dependent?
          Inductors...Air...
          25 January 2011, 09:18 Tuesday
        • TNRRClassic
          Solen 10 and 12 awg inductors
          by TNRRClassic
          Does anyone have experience with the 10 awg or 12 awg air core inductors from Solen? I am wondering if they are a good substitute for foil inductors, as the resistance is about the same. Also, they are a little cheaper. I've personally iused an air core inductor larger than 14 awg. I've always used...
          13 July 2016, 06:01 Wednesday
