Crossover components.
As I am gathering parts for my build(s) I see many items that have the same values but are different designs and price points. Resistors as an example, metal oxide or wire wound. Is one better than the other? Is it application dependent?
Inductors...Air core, iron core, foil, what matters? Does gauge matter as long as the Mh is the same?
Same questions regarding capacitors.
Thanks for being patient.
