Northwest Audio review.June 4,05
  • RAW
    • Apr 2003
    • 23
    Well after a few months since the DIY event ,RAW Acoustics will be holding a day for those wanting to come and listen to all the kits design from RAW Acoustics along with Exodus.
    For the day we will have the following ready for you to have listen to.
    RAW 1
    RAW 1F
    RAW HT1 CSS125S AC ribbon
    RAW HT2 CSS125ST AC ribbon MTM
    RAW HT3 AC,CSS125S,sidefiring Extremis
    RAW HT6 Extremis and AC ribbon
    Exodus kits
    41
    241
    16
    261
    LCR
    See you then.Maybe Kevin and Dan may hook up for the trip.Should be a good day for a barby!
    For those attending feel free to email direct with your notice you are attending.
    Al
    RAW Acoustics
    16756 -85 Ave
    Surrey BC
    Canada
    604-576-8951
    _________________
    Al
    Got love exotic veneer !
    • 16060
    What's the front end gear like that you'll be demoing the designs on?
    ~Jon
    • RAW
      • Apr 2003
      • 23
      This is what we had John from Bent Audio bring over last time.
      Once I find out for sure I will post it.
      Al
      • RAW
        • Apr 2003
        • 23
        NorthWest Audio review info
        Had a great time Dan from Adire and Kevin from DIY Cable made the drive up and as usual Dan had a few minutes to display his talents in the design theory and those who sat down really enjoyed listening to why the man from Adire does what he does.
        Thanks to all those who made the day a great time.
        Al
        • shane2468
          Quad 405
          by shane2468
          What speakers are suitable for the Quad 405 poweramp?
          29 April 2009, 14:52 Wednesday
          Exploring Common DIY Terminology - Ribbon
          by technodanvan
          Ribbon
          A ribbon tweeter is a type of high-frequency transducer used in loudspeakers to reproduce the treble and upper midrange frequencies. It is called a "ribbon" tweeter because its diaphragm is typically a thin, narrow strip of metal foil or film that resembles a ribbon. The ribbon diaphragm is suspended in a magnetic field, and when an electrical current passes through it, it vibrates back and forth to produce sound. This design comes with several advantages:
          • Lightweight
          23 July 2023, 08:24 Sunday
        • DIY_newbie
          One side of my open baffle finished in Raw MDF
          by DIY_newbie
          w00t w00t...
          For those following my project, I decided to go with a shorter Mid/tweet panel 19.5" wide x 18" tall with a 6" floor instead of the 19.5" x 24" with side panels. BDS and my cardboard work showed very little difference between these two designs and the...
          24 September 2005, 21:03 Saturday
          Fountek ribbon repair....
          by Jim Holtz
          Recently there were discussions in a thread about repairing/replacing the ribbon elements in Fountek ribbons so I decided to email Madisound and find out what it cost to replace the elements. I recieved a prompt reply from Josh stating that the only charge for repair was the price of the element and...
          21 April 2008, 16:03 Monday
        • indygreg
          Why wouldn't a ribbon based MTM be ideal for home theater
          by indygreg
          been reading a number of posts and was curious why an MTM using a ribbon like a raven would not be ideal for home theater? the downside to the ribbons is their lack of vertical dispersion but that is a big plus for home theater.
          greg
          05 January 2007, 22:15 Friday
