Xbox 360 remote?
  • maseline_98
    • 317
    Xbox 360 remote?
    Am I able to use the learning functions from my URC to get the commands from the xbox 360 remote? I thought I would be able to just learn the commands from the controller itself, but that didn't seem to work....I'm really only trying to use the remote for LastFM.
    This is the remote I was looking to buy (cuz it's only $5)
    Sony kds-60a2000\Panasonic BD-55k\XBOX 360 Premium(20gig)Slingbox\Xbox(flashed) running XBMC
    Emotiva UMC-1\Emotiva XPA-5\Klipsch (2)RF-7s with DeanG xover upgrade, RC-7 with DeanG xover upgrade, (2)RS-7s\SVS 20-39PC+
    _____________________________
    “Insanity: doing the same thing over and over again and expecting different results.” - Einstein
  • Kevin D
    • 4601
    What model URC? The computer programmed ones have the 360 codes in the database. Otherwise, yes the 360 remote is IR and you should be able to learn it fine (controllers are RF).
    Kevin D.
    • maseline_98
      • 317
      Kevin D.
      Nope...it's an old one...WR7....
