Seen a lot of poor press for ME in HTPC systems. As a lark, and on a personal dare (never get in aruguments with yourself), today I installed Windows Me on my bedroom HTPC. With the full uninstall capability retained, of course!
Negative I've heard at other forums include jerky video, problems with audio in DVD playback, etc.
What I found, was that Me gives you NO options for setting configuration when installing, but it DID do a good job of keeping and converting all my old configuration- so a HTPC set up to be lean an mean, with no scheduling agent, no crud hanging around the systray, etc, stayed in that configuration.
Only tried out portions of a few DVD's, some torture tests from "WaterWorld", "Desperados", "Lost in Space", but everything has been smooth sailing, and now finally the shutdown operation is glitch free on my Athlon 750 system.
So, will watch a movie tonight, if anything strange comes up, I'll report. My feeling is, if the system that you upgrade is properly configured for HTPC, it will be very simple to upgrade (this was the fastest, no brain, no choices install I've ever seen from Redmond). But, possibly, if you don't have an optimum HTPC configuraiton, Me will give you no chance to tweak that while installing, and what you THEN wind up with may be very non optimum, as others report.
For reference, my configuration:
ASUS A7V MB
750 MHz Tbird Athlon
128 MB PC133 SDRAM
ELSA Gladiac Geforce 2
Hitachi 8X DVDROM drive
Sound Blaster Live Platinum Sound card, Liveware 3
Resolutions run are 1024X768 and 1280X720.
ASUS A7V MB
128 MB PC133 SDRAM
