Classic Computing
  • Bing Fung
    • 6523
    Classic Computing
    What do you think, can Computers make some classic comeback in collector appeal like vintage cars?
    Here are some beauties that should make you salivate...
    NAME CHALLENGER III
    MANUFACTURER OHIO Scientific
    TYPE Professional Computer
    ORIGINE U.S.A.
    YEAR 1978
    CPU 6502 + 6800 + Z80/8080
    SPEED 1 Mhz / 2 Mhz
    RAM 32 KB (up to 1 MB !)
    ROM Unknown
    I/O PORTS Expansion slots
    BUILT IN MEDIA One or two 8'' disk-drives
    OS OS-65U, OS-65D, CP/M
    POWER SUPPLY Internal P.S.U.
    PERIPHERALS RS-232 card, Centronics card, etc.
    PRICE $3481 with a dual F.D. drive unit
    This computer is an enhanced version of the Challenger IIp. The motherboard was equiped with 3 microprocessors: 6800, 6502A and Z80. An optional 74 MB harddisk was available ($6000 !).
    _________________________________________________
    NAME MZ 80K
    MANUFACTURER Sharp
    TYPE Home Computer
    ORIGINE Japan
    YEAR 1978
    BUILT IN LANGUAGE Basic available on tape
    KEYBOARD Strange transparent square keys. 78 keys. Numeric keypad
    CPU Sharp LH-0080 (Zilog Z80 A compatible)
    SPEED 2 MHz
    RAM 20 KB (up to 48 KB)
    MZ-80K2 & K2e: 32 KB
    ROM 4 KB
    TEXT MODES 40 x 25 (8 x 8 character matrix)
    GRAPHIC MODES 80 x 50
    COLORS built-in 10'' black & white monochrome monitor
    SOUND one channel
    SIZE / WEIGHT 410 (W) x 470 (D) x 270 (H) mm / 13 kg
    I/O PORTS Expansion bus
    BUILT IN MEDIA Tape recorder
    POWER SUPPLY Built-in PSU
    PERIPHERALS RAM expansions, printer, color display
    PRICE MZ-80K: 198,000 yen (1978, japan)
    MZ-80K2: 198,000 yen (1980, japan)
    MZ-80K2e: 148,000 yen (1981, japan)
    NAME ABC 80
    MANUFACTURER Luxor
    TYPE Home Computer
    ORIGINE Sweden
    YEAR 1978
    BUILT IN LANGUAGE Luxor Basic
    CPU Z 80
    SPEED 1 MHz
    RAM 16 KB (up to to 32 KB)
    ROM 16 KB
    TEXT MODES 40 x 24
    GRAPHIC MODES 78 x 75
    COLORS Monochrom
    SOUND 1 channel
    I/O PORTS V24 / RS232 -
    BUILT IN MEDIA Optional 2 x 5.25'' disk-drives
    NAME 400
    MANUFACTURER Atari
    TYPE Home Computer
    ORIGINE U.S.A.
    YEAR 1979
    END OF PRODUCTION 1982
    KEYBOARD QWERTY membrane keyboard, 61 keys
    4 function keys (Reset, Option, Select, Start)
    CPU 6502
    SPEED 1.79 Mhz
    COPROCESSOR ANTIC (Scrolling, Sprites, Video), CTIA / GTIA (Color, Sprites, Collisions), POKEY (timers, sound, keyboard, serial I/O), PIA 6810 (I/O, including the 4 joystick ports)
    RAM 8 kb or 16 kb (newer models)
    ROM 10 kb
    TEXT MODES 40 x 25
    GRAPHIC MODES several graphic modes, maximum : 320 x 192
    COLORS 16 (each color can have 8 luminances) = 128 colors maximum in the lowest graphic mode (requiring display list interruption to have them simultaneously)
    and up to 256 colors in some specific modes for machines having the GTIA chip instead of the CTIA
    SOUND 4 voices, 3.5 octaves
    I/O PORTS RGB video output
    1 cardridge slot
    Expansion bus
    Atari Serial I/O (SIO)
    4 joystick sockets
    Tape recorder
    OS 400/800 OS in ROM
    __________________________________________________
    NAME Hantu
    MANUFACTURER NBI
    ORIGINE U.S.A.
    YEAR 1975
    KEYBOARD Full-stroke professional keyboard with two keypads (numeric and editing ?)
    CPU Intel 8008
    RAM up to 16k
    SIZE / WEIGHT Indecent...
    BUILT IN MEDIA 2 x 8'' floppies, (250k each)
    POWER SUPPLY PSU built-in
    NAME 8080
    MANUFACTURER IMSAI
    TYPE Home Computer
    ORIGINE U.S.A.
    YEAR 1975
    KEYBOARD None, front panel switches are used to program the system
    CPU Intel 8080A (rarely 8080)
    SPEED 2 MHz (each instruction takes 4 clock cycles)
    RAM 256 bytes
    ROM Unknown
    TEXT MODES None (optional 64 x 12 card)
    GRAPHIC MODES None
    COLORS None
    SOUND No I don't think so
    SIZE / WEIGHT Unknown
    I/O PORTS I/O port
    OS Unknown
    POWER SUPPLY Unknown
    PRICE Unknown
    This is the computer used in the movie Wargames!
    A friend of mine said the U of S sold this same PC for $50, then the buyer then turned around and sold it on Ebay for $1000 just because it was in the movie..
    NAME 820
    MANUFACTURER Xerox
    ORIGINE U.S.A.
    YEAR 1982
    END OF PRODUCTION 1985
    BUILT IN LANGUAGE Basic 80 delivered on disk
    KEYBOARD AZERTY/QWERTY, full-stroke keyboard with separated keyboard
    CPU Zilog Z80 A
    SPEED 2,5 Mhz
    RAM 64 kb
    ROM from 4 kb to 8 kb
    TEXT MODES 80 x 24
    GRAPHIC MODES Unknown
    COLORS Black and white 12'' monitor
    SOUND Unknown
    SIZE / WEIGHT Main unit/monitor : 32,8 x 38,1 x 34,3 cm / 13,6 kg
    I/O PORTS Serial 9600 bauds, Internal Expansion Slot, External Floppy Connector
    BUILT IN MEDIA One or two 5.25'' disk-drives (80 KB formatted each)
    One or two 8'' disk-drives (160KB each)
    OS CP/ M 2.2
    PERIPHERALS Printers, additional disks
    PRICE With double 8'' disks = 3900 (France, 82)
    8" Floppies??
    NAME PC XT - Model 5160
    MANUFACTURER IBM
    ORIGINE U.S.A.
    YEAR 1983
    KEYBOARD Full-stroke keyboard with numeric keypad and function keys
    84 or 101 keys
    CPU Intel 8088
    SPEED 4.77 MHz
    RAM From 64k to 640k, depending on models
    ROM 64 kb
    TEXT MODES 80 x 24 / 40 x 24
    GRAPHIC MODES CGA modes : 320 x 200 / 640 x 200
    COLORS 16
    SOUND Tone Generator
    I/O PORTS eight internal slots (five 8 bit ISA), RS232c, Centronics
    BUILT IN MEDIA One 5.25'' FDD, 360k (3.5'' on later models)
    10Mb or 20Mb hard-disk
    OS MS DOS
    Bing
    Bing
    • 16478
    Bing I think you have to look older then that
    In 1946, The Electronic Numerical Integrator and Computer (ENIAC), under the direction of J.P. Eckert and John Mauchly of the University of Pennsylvania, was unvailed as the first digital computer. This new creation was a computer that could compute a thousound times faster than any previous machine. Under high stress, the computer could output 5,000 adition and subtraction, 350 multiplication, and 50 division problems per second. Unfortunately, te ENIAC doubled the size of the Mark I, and measuring 18 feet, by 80 feet. After leaving the University of Pennsylvania, Mauchly and Eckert formed their own company, but had a hard time selling their computer to financial institutions, because of the cost. It was $500,000, not including the $1,800 per month electrical bill.
    Eniac
    or a little more modern!
    Univac
    • SiliGoose
      • 941
      The Atari 400 brings back memories. That was my first computer.
      Couldn't fit a case window in it so I upgraded for an IBM PCjr.
      -Sili
      www.campmurphy.net
      • Bing Fung
        • 6523
        Classic stuff Andrew, however I was looking more to what Personel Computers (PC's) can be bought on the open market that is plentifull :LOL:
        Sili, I have had a lot of people reminising with the 8088.s and the Z80.
        Bing
        Bing
          • 27460
          I need to shoot a pic of my Panasonic FX-600 for them. 8086-2 processor, predecessor of the 80286 CPU. A step ahead of the 8088. Believe it or not, lol. dual floppys, and had 2 CPU speeds. Tell me, with a computer slow as shit, why would you want a slow and overdrive position? :?: :LOL:
          Lex
          • Bing Fung
            • 6523
            You wanted more drives because it sounded more awesome :LOL:
            Post a picture of it, like a classic car Lex
            Bing
            Bing
            • Jon
              • Mar 2002
              • 27
              My first computer was a Commodore VIC 20 and I still have it, in working order too... I fire it up every once in awhile to play a few rounds of Gorf
              • Bing Fung
                • 6523
                That's exactly what I'm talking about Jon. See how you fire it up the Vic 20 from time to time to play Gorf, is like pulling a 70's car out of the garage from time to time to go get ice cream :P
                Now if only I can get an IMSAI so I can play with the front buttons to program it
                Bing
                Bing
                  • 16101
                  I'm just a newbie to computers...
                  My earliest computer was a TI Professional, in 1983. Though it came with 5" floppy drives, ThomasW and I actually upgraded ours to 3-1/2" flopyy disks- including quad density ones, which was a big deal in that time.
                  Tom had one that looked like this- the portable:
                  -Jon
                  • Trevor Schell
                    • 10936
                    I love that Atari computer.
                    I remember wanting that one.
                    We still have the Commodore 64 with a color monitor and harddrive in working order. This one brings back great memories of the text based adventure games Zork and Enchanter that I used to play.
                    I still have the Atari 2600..Oh the memories these machines bring back!
                    Nice collection Bing!,
                    Well Done.
                    Trevor
                    My HomeTheater S.E.
                    Sonically Enhanced
                    C5
                    Trevor
                    XBOX 360 CARD
                    • Bing Fung
                      • 6523
                      Oh, all of you with your vintage machines that you pull out on Sunday to wax and play a quick DOS game, I'm so envious... 8O
                      Bing
                      Bing
                      • Jon
                        • Mar 2002
                        • 27
                        Myabe I should take a picture of my freshly waxed Vic-20 with the tape drive attached and all Man the loading times were pathetic with that thing!
                        • Bing Fung
                          • 6523
                          Hey Jon, I think we need a picture of you Quaking on the Vic 20...hehe that would kill you to run at 0.0002 frames per/sec, if you could even get it to run :LOL:
                          Bing
                          Bing
                          • Jon
                            • Mar 2002
                            • 27
                            See I think the main issue with that would be the 3k of usable memory, Quake 3 would need some serious optimizing! I'll be in Regina this weekend and will pick it up the ole Vic, Maybe hook it to my Living room TV I don't know how good 20 column resolution would look on 32" of screen.... heh heh.
                            Any one here play Quake 3? My squad needs a few good Canadian players
                            • Bing Fung
                              • 6523
                              Well you know me and 1st person shooters Jon, I'd hurl 8O ops:
                              I'am getting better though...
                              Bing
                              Bing
