I want to build a computer desk for my MacBook Pro that has an "Apple" theme to it, if you have ever visited an Apple store you will know the large, blocky, light colored wood desks that all of the Mac's sit on. As I was designing the "perfect" desk to hold my laptop, monitor, keyboard and mouse, I looked over at my 8 year old Altec-Lancing speaker system (which is slowly on its way out ) and realized I wanted some replacement speakers/audio system. I looked around at what other "computer" speakers were available and really their is not much out their. Everything is 5.1 and made out of plastic. I just want a 2.1 setup that sounds great. So, why not build my own? I built my own fiberglass sub box and wired numerous audio devices in my car.
So what does the speakers have to do with the Desk? I want to integrate the speaker system with the desk to hide as much of the wire clutter, amps etc that detract from the simplicity of having a clean desk with just 4-5 things on it. The Mac laptop I have is all brushed aluminum and glossy black/glass, the Apple display is also the same, as is the keyboard. Drawing on those designs I want to design two speakers that have similar strait lines and rounded edges, silver on the outside L/R/T/B and the front and back would be plexiglass face painted black from the inside to create a similar glossy finish.
Here are a few digital drawings of how the finished product might look.
So thats what I can do, I have the general design, I also know what drivers I plan on using for each speaker.
2x HiVi B3N 3" Aluminum Driver Round Frame [15w@8ohm]
1x HiVi B4N 4" Aluminum Midbass Round Frame [25w@8ohm]
1x Dayton ND16FA-6 5/8" Neodymium Dome Tweeter [10w@6ohm]
The amp I plan on using to power the two speakers is
Dayton DTA-100 Class-T Digital Amplifier 50 WPC [50w@8ohm]
I need help designing the enclosure size/shape and the crossovers for the speakers. I have a general understanding of the terms and electronics needed to build the crossovers. I am thinking of doing a 3way setup. Tweeters highpass, 2x 3" drivers mid bandpass, both sealed in the same part of the enclosure. The lower portion would be separate and contain the 4" crossed over to act as more of a woofer and would be ported. I plan on wiring them in series + parallel which should give me ~ an 8ohm load. But I would exceed the power of the T-amp by about 15w....
I currently have 4x 3" drivers, 2x tweeters, and one T-Amp to play with. It seems to be able to run 4x 3" 15w drivers in series+parallel @8ohms just fine with plenty of loudness. Not sure if I should use a third 3" as the crossed over and ported woofer or move up to the 4" @25w.
Out of the speakers I want to get nice highs, mids, and some lows. The rest of the low end will come from the Sub woofers. But one of the most annoying things about a computer speaker system is the subwoofer sitting under the desk and all the additional wires running two and from it.(typically it contains the amp for the entire system) This is where my custom desk jumps in. It will house the subs and amps inside of it allowing me to use up otherwise waisted space. It will also be really neat for gaming as the desk will vibrate a little. I'm not set on the design of the inside but here is a basic concept. Mount the amps in the middle, put the subs in separate boxes that are mirror images of each other. I plan on using the same 50w/ch@8ohm T-amp that I am using for the two speakers. This way I can selectively control the sub volume and speaker volume right up front easily.
Here are two shallow subwoofers I am looking at to pair with the T-amp from above
Tang Band W6-1139SI 6-1/2" Subwoofer [50w@4ohm]
or
Dayton DC200-8 8" Classic Woofer [60w@8ohm]
So my questions would be, whats the best shape/size box to use and which is going to give me the best performance with that amp? I will also need help designing that crossover.
I plan on creating the speaker boxes with a digital design and printed on 2 layers of 1/4" MDF that I will then glue and assemble like a puzzle. This will let me test a design before committing to it and spending hours building the box etc. If its to big/small I can simply adjust the design and get a new part printed. The then 1/2" thick MDF box will be slid into a rounded square box to give it the Apple look I am going for. These will be glued and clamped together to create an overall 3/4" thickness of MDF. Plexiglass will be laser cut to fit the shape of the box and sit in a lip just inside the border of MDF and be screwed to the box at the corners. The speakers will mount directly to the MDF with a cutout in the plexi to make them mount flush.
So in summary, I have 4x 3" drivers, 2x tweeters, 1 T-Amp to experiment with before buying additional components. Here is what I need help with…
- Best way to wire/configure the drivers to best match the amp power output
- Designing a 3way crossovers to work well with the chosen drivers for the speakers
- Design an enclosure that is sealed for Mids/Highs and Ported for a single low driver
- Select the best subwoofer to match the T-Amp
- Design the subwoofer enclosure
- Design a low pass crossover for the subwoofer
If anyone has any ideas/suggestions/comments I would love to hear them. The main goal of this project is a clean design and stealthy components. I also want it to sound better than an off the shelf logitech "computer speaker" system. Any help you can provide would be greatly appreciated!
or
