Ok it seems I've got a problem with IE6 on my XP box. It seems that links in websites that open up a new window aren't functioning properly. What happens is that it opens a new window but its blank. I've tried to uninstall IE but all that seems to do is remove the link from the start bar etc since when you go to reinstall it it only adds 1 meg and all the settings are the same. I've also tried to revert it back to its original settings but it makes no difference. I've also tried that XP rebuild command that I posted in the tips and tricks thread but again no effect...any suggestions?
IE6 problem
Tags: None
Hey Andrew,
Has this problem just started, or has this been happening for awhile? You might want to check your MTU settings. Do a search on the net on how to change it in XP. There are also programs that can change it for you if you don't want to play with your registry.
Jeremy Santos
My Software
Santos Theater
Play It Loud, Play It Clean!!!!!
