Need earphone adapter!!
  • madmac
    • Aug 2010
    • 3122
    Hey all, I'm going into an apartment soon and I believe my two, 250 watt subwoofers are NOT going to be very popular!!. I expect to do a lot of listening with my Grado headphones. My Rotel amp does not have a headphone jack sadly!!.
    How do I set myself up to be able to use my headphones with it???
    Dan Madden :T
  • stuofsci02
    • 1241
    madmac,
    In general headphone jacks are going to be on your preamp... What do you use as a preamp?
    Main System:
    B&W 801D
    Emotiva USP-1 Pre-Amp
    Chord SPM-650 Stereo Amp
    Oppo BDP-105
    Squeezebox Touch
    Second System:
    B&W CM7
    Emotiva UMC-1
    Emotiva UPA-2
    Oppo BDP-83SE
    Grant Fidelity DAC-09
    • madmac
      • Aug 2010
      • 3122
      madmac,
      I have a Rotel A/V receiver. My CD player has a jack but I want to use the headphones for movies too.
      Dan Madden :T
      • stuofsci02
        • 1241
        Your Rotel Receiver does not have a headphone out?
        That is too bad.. Would have made things easy..
        Main System:
        B&W 801D
        Oppo BDP-105
        Squeezebox Touch
        Second System:
        B&W CM7
        Emotiva UMC-1
        Emotiva UPA-2
        Oppo BDP-83SE
        • madmac
          • Aug 2010
          • 3122
          Is there not some form of powered 'headphone jack/ amp' that can be hooked up to the 'tape out's' of receivers and amps that do not support a headphone jack??.
          Dan Madden :T
          • stuofsci02
            • 1241
            There are a ton of headphone amps and DACs with headphone amp built in, but most will take an analog stereo input or a digital input (USB, Coax, Optical etc.)
            Main System:
            B&W 801D
            Oppo BDP-105
            Squeezebox Touch
            Second System:
            B&W CM7
            Emotiva UMC-1
            Emotiva UPA-2
            Oppo BDP-83SE
            • madmac
              • Aug 2010
              • 3122
              Where would I find such a device here in Canada??.
              Dan Madden :T
                • 4151
                Here you go- https://www.ttvjaudio.com/store/come...p?idProduct=31
                Depending on your budget I'm sure he'll ship to Canada!
                • stuofsci02
                  • 1241
                  Here you go.. Based out of Calgary..
                  I have the DAC-09 which has now been replaced by the DAC-11..
                  Here is how the DAC-11 can be used in typical applications.
                  There is a big price range there, so I am sure you can find something that fits the bill.
                  Cheers
                  Main System:
                  B&W 801D
                  Oppo BDP-105
                  Squeezebox Touch
                  Second System:
                  B&W CM7
                  Emotiva UMC-1
                  Emotiva UPA-2
                  Oppo BDP-83SE
                  • madmac
                    • Aug 2010
                    • 3122
                    Cheers
                    Thanks a lot for this info. Is there any reason why this thing uses vacuum tubes??. I mean, it's just a headphone amp for god's sake!!???
                    Dan Madden :T
                    • stuofsci02
                      • 1241
                      People like tubes
                      Main System:
                      B&W 801D
                      Oppo BDP-105
                      Squeezebox Touch
                      Second System:
                      B&W CM7
                      Emotiva UMC-1
                      Emotiva UPA-2
                      Oppo BDP-83SE
                      • madmac
                        • Aug 2010
                        • 3122
                        I see there''s a lot of these headphone amps out there!!. Some for as little as 30 bucks. I your humble opinions, how much of a difference in sound can I expect from one costing 30 bucks vs 200???. Bare in mind that I have Grado SR80 headphone worth about 150 bucks.
                        Dan Madden :T
                        • stuofsci02
                          • 1241
                          I am not sure.. I am not much of a headphone guy. I think it would be like anything in audio though.. At least at the entry level, spending more usually gives much better results.
                          I have read that the Grant Fidelity DAC-09 is quite a good headphone amp for the price. It is replaced by the DAC-11 now, but you might be able to find a DAC-09 used.
                          Cheers
                          Main System:
                          B&W 801D
                          Oppo BDP-105
                          Squeezebox Touch
                          Second System:
                          B&W CM7
                          Emotiva UMC-1
                          Emotiva UPA-2
                          Oppo BDP-83SE
                          • madmac
                            • Aug 2010
                            • 3122
                            Cheers
                            Thanks for pointing me in the right direction :T
                            Dan Madden :T
                            • boe
                              Dolby Headphone Jack
                              by boe
                              So far the Integra is about the only preamp in my price range that has the dolby headphone jack. Has anyone here actually taken advantage of the jack with surround sound headphones? What was your opinion?
                              13 December 2004, 15:23 Monday
                            • Henk
                              No headphone jack on Rotel?
                              by Henk
                              Rotel processors and amps do not have a headphone jack. How does one solve the problem if you wish to listen through headphones?
                              09 June 2003, 05:28 Monday
                            • reddavid
                              Headphones and Control Out
                              by reddavid
                              Aaaaaaahhhhhh Chhhhhoooooooo,
                              Sorry, had to sneeze, shaking the dust off this forum. Look, a new post!
                              Listening to CD/DVD thru headphones - late at night. ACTUALLY, running the B&K headphone out to an SWR bass amp "effects return" and rocking to the tunes...
                              20 October 2001, 09:15 Saturday
                            • xixel
                              RC-1090 Headphone jack
                              by xixel
                              Ok, so I bought a used pre\power amp, everythings been working great - LOVE the rotel gear, I use my headphones often, without a headphone amp handy I've just been plugging it into my preamp (RC-1090)
                              I'm using Beyerdynamic DT-250's (80ohm version)
                              For weeks it was fine,...
                              12 January 2006, 04:10 Thursday
                            • whmacs
                              Headphone amp for RSP-1098?
                              by whmacs
                              Hi All,
                              I'm contemplating getting a headphone amp for my RSP-1098 to improve two channel listening (I've got Jamo THX speakers which are great for movies, but not so good for music). I am tossing up between the MF XCAN v3 and the Creek OBH21SE. I've currently got a pair of Senn HD570 headphones,...
                              07 May 2004, 16:19 Friday
