HTPC as Pre/Pro
  • crackyflipside
    • Nov 2006
    • 197
    HTPC as Pre/Pro
    The biggest issue I need to figure out right now is how to run various external inputs through the PC to the projector. Especially HDMI multi-channel audio.
    -Chris B
    ;x( DIY
    • 16120
    Problem with doing this is that there aren't many sound cards that sound real good.
    • crackyflipside
      • Nov 2006
      • 197
      I've heard some very good things about this soundcard:
      http://www.newegg.com/Product/Produc...%20Elite%20Pro
      (Creative Sound Blaster X-Fi Elite Pro)
      -Chris B
      ;x( DIY
        • 16120
        I would go for the Auzentech version as their drivers are MUCH MUCH better. Creatives drivers are generally crap.
        http://www.newegg.com/Product/Produc...uzentech%20Xfi
        Probably one of the better sounding cards for HT as well and still uses the Xfi chipset. There is an HDMI card that you can get for it (not sure if its out?) but it will pass the new lossless formats over HDMI with it.
          • 16120
          Actually just checked their site and you'd probably be interested in this
          • crackyflipside
            • Nov 2006
            • 197
            http://www.auzentech.com/site/produc...theater_hd.php
            Nah, I am looking for something to go directly from the PC -> amplifiers. No receiver at all.
            You have any ideas on how to run, let's say, a PS3 into the PC. So PC then does processing on video and audio then outputs to the projector?
            -Chris B
            ;x( DIY
              • 16120
              That card has analog outputs as well. If you want to decode DTS-HD MA and True HD you need a card like that. I have not seen anything that will let you input HDMI on the PC. Honestly I think your going to have a hard time using it the way you are wanting to.
              • crackyflipside
                • Nov 2006
                • 197
                Me too. :rofl:
                I'll probably end up buying a cheap receiver... Why can't there be any cheap pre-pros...
                -Chris B
                ;x( DIY
                  • 16120
                  UMC-1 699 and will do anything you want... and since you already have an amp? No need for the internal amps. 5 HDMI inputs and plenty of connectivity. They said the 699 will go for all pre orders but later price might go up.
                  • fhsun
                    New Classic Pre/Pro & Rotel Pre/Pro
                    by fhsun
                    Hello, has anyone had the chance to listen to both New Classic pro/pro and compared it to Rotel pre/pro? Namely 7100 vs Rotel 1068?
                    Are they sonically similar or very different? How would you describe the Parasound sound?
                    The pre/pro would be driven by a Rotel RMB-1075...
                    13 November 2008, 16:37 Thursday
                  • Bob Sorel
                    Tha Amazing Tag McLaren AV32R-EX pre/pro...all the right stuff!
                    by Bob Sorel
                    Every once in awhile in the audio world a piece of equipment comes along that is so incredible that it deserves special mention among a plethora of mediocre components, and the new THX EX equipped Tag McLaren AV32R is one such piece. Never since I first got my Dynaudio speakers has any single component...
                    27 December 2000, 19:24 Wednesday
                    High-End Soundcard for HTPC
                    by audioqueso
                    RME 9632 Soundcard. Anyone ever heard of it?
                    I just heard of this soundcard, and started wondering if this is a good option for me. I want to make my HTPC as good as a good CD player. I've been asking a few guys over at AVS about it, but haven't really heard from anyone who's owned that soundcard....
                    06 May 2009, 00:35 Wednesday
                    HTPC ... Help me pick the parts! :)
                    by aud19
                    So I'll be building a HTPC for\with a friend of mine in Feb-March. I understand a lot can change in a month or so but I'd love to know if I'm on the right track, also if anyone knows of some great technology right around the corner...? :P I've built quite a few PC's in the past mostly for my home office...
                    12 January 2004, 23:24 Monday
                  • sajaga
                    HTPC as a preamp and replace RSP1068??
                    by sajaga
                    Hey all,
                    I am not sure as to whether I should part with my Rotel RSP1068 and go it alone with my HTPC directly feeding my RB1080 (200x2) and the RB1075 (120x5).
                    The only thing that I seem to use on the rotel pre is the multichannel input (analog in) from my Meridian 7.1...
                    01 August 2007, 19:40 Wednesday
