Harmony 885
  • georgev
    • 365
    Harmony 885
    I am new to universal remotes and am considering the plunge.
    I am looking at a Harmony 885, and I want to control a family room that has Theatre amp. DVD Player, LCd Panel and Satellite decoder.
    1. Is it easy to set up and use?
    2. Can it be setup that if I press one button the LCD will switch to the input, amp will change source etc?
    When I watch satellite, the amp has to be switched on and source changed, the LCD has be changed to the appropriate source and the distributor has to be switched on.
    If I watch a DVD, the source on the amp and the input on the LCD has to be changed.
    Can I do all this by one button?
    Sorry for the novice type questions.
    George.
  • georgev
    • 365
    Help Anyone?
      Ummm... I don't know the Harmony line at all, but yes, it probably does what you're asking. I just got a Universal Remote MX-980, and that thing ROCKS. Highly recommended. www.urc.com if you want to check out that company.
        • 16128
        Yes it has Watch buttons. You press something like Watch DVD and it will turn on your amp change the source on the amp, turn on the tv change the source on the tv, and turn on the dvd player, or any other number of things that you could possibly need it to do.
        • georgev
          • 365
          Got the remote on a trial basis, and yes it certainly is quite easy to use and I am enjoying it(will probably keep it).
          What I haven't been able to get it to do yet is switch on the PS3.
          Any thoughts?
            There are a few products on the market today that plug into the PS3 ports, receiving IR signals to remotely control the PS3, instead of the standard bluetooth PS3 control.
            • georgev
              • 365
              Which ones are there?
                I use one, I think it's made by schmartz.com, that is a USB dongle that receives IR codes. Just use any remote control that has the IR codes for the PS2, after that. Works great, for me.
                • georgev
                  • 365
                  Thanks Chris, went onto the website and looked at them, have mailed Mike. Does yours do the on off function as well?
                    Ummmm... mine doesn't, but I'm pretty sure Mike has a brand new version out now that does. I don't mind, though. I usually leave my PS3 on, anyway, to crunch Folding @ Home, but if I do need to turn it on, I'm usually doing it by putting in a disc anyway, or something, at the unit.
                    • georgev
                      • 365
                      Have ordered one from Mike that also does the on/off function. Waiting for it.
                      Will keep you posted.
