Need sound card/software for PS3
  • riceaterslc
    • 205
    I want to hook a PS3 up to my computer so i can get 5.1 to my computer speakers. I will be running HDMI for video directly to my television. I am not too familiar with the PS3 but i want to run an optical digital cable from the PS3 to the computer, and have 5.1 output via speaker outs. i am not too smart on the decoding aspect, if i need software, if a sound card can do it, etc. what would you guys recommend? thanks :T
    chris
  • dyazdani
    • 7032
    What about this?
    Danish
    • riceaterslc
      • 205
      jeez that was fast
      that looks exactly like what i need. however, how does it handle the HD formats like trueHD, etc? does the PS3 output these formats?
      chris
        The PS3 does output those sound formats, but only over HDMI. (every player does this--optical and coax do not have sufficient bandwith)
          • 16120
          HD audio formats can only be transfered over HDMI. Also most sound cards do not accept multichannel input so it may be a problem. If you do optical out of your PS3 it would convert the HD stuff into high bitrate PCM.
