Capture card with DVI or component input?
  • Drewbert
    • Aug 2005
    • 104
    I was wondering if anyone knew of a capture card that had this, as I cannot find one. I want to use my set top box and use my pc as a DVR.... but I just dont think the technology is there....
    Any ideas?
    -Drew
  • Vinny
    • 252
    You don't see many of those capture cards are on the market for component because the last 2 generations of the video cards are now equipped component video in(those higher models like ATI All-In-Wonder series). If your computer can take PCI-express card, pick one of those cards up as you get video card upgrade in the same time :B
    Mostly are just component, I've never seen a DVI input though.
    Pioneer KRP-500M
    Emotiva UMC-1
    Parasound 5125
    Oppo BDP-83
    Klipsch RF-3II, RC-3II, RB-5II
    SVS PB-10NSD
    • Drewbert
      • Aug 2005
      • 104
      can you link me to what youre talking about?
      -Drew
      • Arneson
        • 240
        The Dazzle is an excelent easy answer. I have the DVC 80, plugs into usb works great with XP. Has audio composit and S.
        • Vinny
          • 252
          Yea it's easy to find a composite and S video capture card. They are pretty much everywhere. But component an DVI input do not come easy.
          Pioneer KRP-500M
          Emotiva UMC-1
          Parasound 5125
          Oppo BDP-83
          SVS PB-10NSD
          • Vinny
            • 252
            For ATI products take a look of these:
            AMD delivers leadership high-performance and adaptive computing solutions to advance data center AI, AI PCs, intelligent edge devices, gaming, & beyond.
            nVidia's card you will have to look around as they have different features from various manufactors.
            Basically they are video card equipped component in and allow you for some recording over component.
            Pioneer KRP-500M
            Emotiva UMC-1
            Parasound 5125
            Oppo BDP-83
            SVS PB-10NSD
            • Marzen
              • 302
              Here's someone that seems to have done a lot of research on STB HDTV to pc based recording. LINK
              -Ward
              What if the Hokey Pokey really IS what it's all about?
