Balanced power
  • kgveteran
    • 865
    Balanced power
    I thought that my dedicated 20amp line were the end all ? I went to the site for balanced power and downloaded all the FAQ.
    I understand that a total system would do justice better, but to get my feet wet, could I start with the 20a line that feeds my line level equipment ? Would i hear sutle changes?
    On to bigger area's What size system if any (I'm not sure of the benifits balanced power has on amplifiers )for my three B&K ST-140's and (4) QSC 1450's.Then the NEC projector.
    The DIY pages show the building of the boxes and would be a snap to put together.
    Now, in my sevice panel earth ground is also neutral, since they combine them all in the box..Seems that my earth ground rod would have to be connected to this power system before it reached the service panel ? Just a little bit more common language would help.
    Thanx, this is a very exiting idea.I know, I gotta get out of the house more if this is an exiting idea.
    In a nutshell BP lowers the noise floor of the AC line (this is called common mode rejection). For most people that provides improvement for both audio and video.
    The fact that the ground and neutral are bonded at the main panel, doesn't mean they're supposed to be together anywhere else in the system!
    Portable BP devices simply plug into a wall outlet.
    If you hardwire in a BP device you just attach it to the black/white/green like any other device.
    Don't make any changes to your grounding rod's connection to the main panel nor should you run a direct lead run from the ground rod to the BP device.
    If you don't have a reasonable understanding the basics of whole house wiring and how a main panel operates, stick to portable units that just plug into an existing wall socket. The 'magic smoke' released from a botched AC line wiring job is a bit more problematic, than that from a miswired crossover....
    DO NOT plug your NEC CRT projector into a BP system. Information gleaned from a long AVS trouble shooting thread, leads us to conclude the NEC FP CRT's power supply doesn't tolerate voltage on the neutral leg. Now we haven't choosen to test this conclusion, given the rather high price of admission for a replacement power supply should our conclusion prove true. Standard (non-balanced) isolation transformers work fine on the projectors, I've always used one of these on my XG.
    • DIY_newbie
      My balanced power project part I (pictures)
      by DIY_newbie
      I got tired of waiting for my repaired ribbon so i could complete my main speaker project so I decided to start working on the quitech transformer in a box.
      This thing is huge!!! 90lbs and 12" in diameter !!!
      10 guage OFC wire for internal hot/neutral...
      08 May 2005, 21:12 Sunday
    • kingpin
      Wiring from main panel
      by kingpin
      Mods: I didn't know where to list this topic as the other areas of the forum don't seem to have much action going on.
      I am moving into a place where the power goes down a lot.
      I have invested a lot of money(for me) in my electronics and would like to keep them as safe as possible....
      01 January 2007, 11:57 Monday
    • HedgeHog
      SSP to Amp Balanced Pinout - Ground Lift: Yes/No?
      by HedgeHog
      Hi all,
      I was wondering what the consensus is for balanced cables between an SSP to the amp? Googling seems to indicate a preference towards ground-lifting at the pre/pro side to eliminute buzz/hum (except for mics). However, the SSP-800/CA-5200 manuals hint at all pins connected. ...
      08 May 2009, 15:20 Friday
      Rebuilding the Transcendent Sound Balanced Power Supply
      by ThomasW
      For those that haven't seen the original thread about the construction of this power supply HERE'S a link to that thread.
      After a month of living with the stock unit, I decided it was time to upgrade.
      First to go was the single residential grade receptacle and the silly outlet...
      28 July 2004, 23:55 Wednesday
    • Brandon B
      Yet another ground hum . . .
      by Brandon B
      OK here's one I can't figure.
      Got a rack ful omc stuff, and the only place I get any noise is from my sub (ground hum). To make it worse, it is only when my Symmetrix 551E eq iss in engaged mode.
      In other words, no hum at all when the system is used with the eq in the loop...
      18 July 2002, 09:17 Thursday
