Yet another ground hum . . .
  • Brandon B
    • Jun 2001
    • 2189
    OK here's one I can't figure.
    Got a rack ful omc stuff, and the only place I get any noise is from my sub (ground hum). To make it worse, it is only when my Symmetrix 551E eq iss in engaged mode.
    In other words, no hum at all when the system is used with the eq in the loop power and signal wise but bypass button is pushed, but activate it and hum occurs. Tried adding a cheater plug, tried plugging into a power conditioner. It is receiving an unbalanced output from my preamp, and going balanced from there to my amp. They are on different circuits (amp is on a dedicated 30 amp by itself), but all my circuits are on the same 120 leg of my box.
    Am I looking in the wrong place, and this is coming from interaction with the eq and something else? My sub amp has a ground lift switch, but it also has no effect.
    Thoughts?
    BB
    Brandon,
    This doesn't sound like a ground loop issue. That'd be pretty constant. It does sound like some time of interaction or short when the switch is engaged. Have you tried running balanced all the way (if possible), or un-balanced all the way, just as a test?
    David - HTGuide flunky
    Our "Theater"
    Our DVDs on DVD Tracker
      • 16089
      Where is the symmetrix located in relation to other equipment in the rack? Is there a possibility of noise pickup in the active circuits from a nearby power transformer? Either that, or in the bypass mode, there's no active circuitry engaged, and in the active mode, the active circuitry is picking up noise from it's own defective power supply.
      • brucek
        HTG Expert
        • 303
        Brandon,
        I have to agree with David and Jon, that the fault likely lies with the 551, and not a ground loop.
        The 551 in bypass has a relay that completely bypasses the electronics of the unit and hard-wire connects the input to output jacks. The unbalanced to balanced convertion by shorting the connector sleeve(ground) to ring(-signal) is then passed to your subwoofers input differential receivers as opposed to the 551's input receivers when bypass is dis-engaged.
        In this bypassed condition the subwoofer is silent, while still using the 551 only as a connector mounting point. The 551 is still passing the ground and still provides safety ground. Only its electronics is removed. Not a ground loop problem....
        When you dis-engage bypass, you enter the 551's electronics into the mix. There are now many possibilities of faults, but they all point to the 551 electronics, including the power supply may have a faulty filter capacitor (my guess), and any op amp may be faulty...
        In that regard, most of this can be quickly eliminated by disconnecting the processor to 551 cable and only have the 551 feeding the sub amp. Is the hum still there? If so, the 551 likely has an electronics fault.
        I also wonder if you may have a small signal hum eminating from your processor all the time that you also have a filter boosting, and as such, "sounds" much louder when bypass is dis-engaged..
        Anyway, those are a few ideas. Heck it could still be some weird ground loop, although the "cheater" would tend to refute that. But, there are more paths for a ground loop than I've had hot dinners.....
        brucek
          Brandon
          There is a switch inside the 551/552 that will eliminate the hum..
          I had the same problem you describe. Sent the unit back for service. The tech (very nice guy) I talked to called and apologized for having me send it in for service. He said he should have told me over the phone about it.
          Now unforutnately that was 2yrs ago so I don't remember any of the specifics. Pop open the top and look for a DIP switch. Change it's position and see if the hum goes away.
          If you can't find an appropriate switch call their tech support line and they'll walk you through it over the phone.
          • Brandon B
            • Jun 2001
            • 2189
            Great! Thanks to all of you for the answers.
            The unit is right under my 3600 watt crown sub amp, so it very likely could be picking something up from there. I will move it first, and if that fails, will pop it open and check for the switch.
            I had considered maybe I was boosting an already present hum, but I am actually cutting pretty heavily in the 60 Hz band due to a hump. Also, can't run balanced all the way, as my HT preamp (outlaw) gots no balanced outs.
            Thanks. I'll tackle it this weekend and let you know what the culprit was, location or switch.
            BB
            • Brandon B
              • Jun 2001
              • 2189
              Where is the symmetrix located in relation to other equipment in the rack? Is there a possibility of noise pickup in the active circuits from a nearby power transformer? . . .
              We have a winner. It was the 2 crown amps bleeding into it. I foolishly assumed pro audio equipment was intended to all be jammed inn a rack together and would be shielded.
              It's now VERY quiet. Spiffy.
              Thanks again guys.
              BB
              • Frankqa
                SPA1000 and DTA-2.1BT2 hum - speaker out to rca in
                by Frankqa
                I have a DTA-2.1BT2 and I wanted a little more power for the sub. I had an older SPA1000 laying around and figured why not.
                The only problem is that I get a nasty hum from the sub when the DTA-2.1BT2 is turned off. I used a bare speaker wire to male RCA converter that I found on Amazon....
                20 March 2023, 03:57 Monday
              • CWD
                RSP-1068 and ground loop problems
                by CWD
                [This is a long post, but it may be helpful to others that may have to deal with similar problems....]
                I upgraded from a Denon AVR-2700 receiver to the Outlaw Audio 755 amplifier+Rotel RSP-1068 in that order, in two steps, about 6 months apart. When the Outlaw amplifer showed up with...
                20 June 2004, 10:11 Sunday
              • Highroller
                Ground loop problem to my 802di fronts and HTM2di center
                by Highroller
                I have a hum in all three of my front speakers.
                The two fronts and center are connect to seperate MC501s connect to their own dedicated circuits.
                The MC501s are connected to an MX120.
                I have an MC207 connected 803S's in the back. The MC207 is connected...
                06 March 2011, 23:09 Sunday
              • hamiltong
                Another - RMB 1095 Ground Loop / Satellite
                by hamiltong
                Like many others before me - after installing all my new toys (RSP 1068 & RMB 1095) - I now have the infamous ground loop hum. God it's annoying.
                It's definitely attributed to my satellite coax feed. When unplugging the coax from the SAT receiver hum is gone. Or unplugging the S-Video...
                31 March 2004, 23:34 Wednesday
              • scottnow
                Rsp-1570 Hum!!
                by scottnow
                Hello all,
                I am experiencing a dreaded ground loop hum with my new setup. I have an RSP-1570 connected to a RB-1572. With only the 2 audio interconnects, if I connect my TV via HDMI (Pioneer 60" Plasma) I get the hum out of the speakers. Disconnected, no hum. I have tried all...
                26 August 2009, 23:14 Wednesday
