arcamdv29 interfering with Krell Pro
  • kurtholz
    • 345
    Hey all
    Iv'e been trying to work thru this, but the arcamdv29 i just bought, its remote is interfering with the Krell processor, i have to hold my finger over the sensor that gets the signal from the krell to use the remote
    havent had time to try and figure out how to program it into my pronto,( which i probably can't do anyway)
    has anyone had other brand remotes interfere with other components like this before
    i am planning on upgrading my pronto, havent decided which way to go as far as a different brand , so i don't want to pay to have the one i have reprogrammed right now anyway
    any suggestions
    other than holding my finger over the infra red window while using the remote, hahaha, isn't it always something
    thanks
    Kurt
  • Azeke
    • Mar 2003
    • 2123
    Kurt,
    I will move this thread to the Remote Control forum where you may get better responses.
    In the interim, you may want to check out remotecentral.com they may have the file(s) you need for your pronto.
    Best regards,
    Azeke
    • kurtholz
      • 345
      as alway's, thanks so much
        Pronto TSU3000
        by Andrew Pratt
        Philips reveals successor to the Pronto TSU2000 – part 1!
        Waiting for a Pronto remote with more hard buttons? You may not have to wait much longer! Philips is revamping the black and white TSU2000 remote as a new model – the TSU3000, which will be shown later this month at...
        02 October 2002, 22:01 Wednesday
        Pronto Neo
        by Andrew Pratt
        No this isn't a prop from the next installment on the Matrix its philips latest pronto remote. Marantz is about to release the 5200 and the 9200 which I've copied the specs from the remotecentral site. anyway the Neo is supposed to be like the marantz 3200 which uses the same physical body that the...
        12 October 2001, 23:17 Friday
      • jltrdavis
        Which Philips Pronto to buy?
        by jltrdavis
        Seems like many people here are using the Philips Pronto remote. Which model is everyone using? Which model works the best with Rotel?
        - Jason
        14 January 2003, 15:30 Tuesday
      • Karma
        Kudos to Krell's Kustomer Kare
        by Karma
        HI All,
        Two weeks ago I dropped my TV remote on the remote for my Krell KAV280P preamp from a height of about 2 feet. Disaster!! The Krell remote was dead, dead, dead and it was my fault. No warrany issue here.
        After determining that it's death was final, and with nothing to loose,...
        09 March 2006, 09:55 Thursday
      • daidavel
        RSP-1098 STANDBY Mode
        by daidavel
        The manual says that in Standby mode you have to press the power on the front of the unit, or use the power on the remote control to turn the unit on. I'm finding that pressing ANY key on the remote turns on the unit. This is a little bit annoying, because I have a Pronto Remote, which I have programmed...
        29 January 2004, 21:16 Thursday
