I am looking for an external fan, if there is one, to put in the side of my computer cabinet for additional cooling. I don't think the case has room for another fan, but it is inside the cabinet which has a closed back. Any advice would be great.
Exhaust Fan
by greenhornHere's the deal. When I first got my Pre-Amp and Amp the Amp didn't go into the cabinet with the Pre-Amp, DVD Player, Cable Box...I had it outside as I didn't think it would fit well.
Wife really prefered that it would go in the cabinet, so I ditched the VCR, did some re-arranging and...-
Channel: Audio Hideout
by AngioguyJust thought someone out there might be able to suggest a good company that makes small clip-on or wall-mountable, ultra-quiet cooling fans for placement inside an enclosed rack system. I would prefer an AC powered unit, and if possible, one that activates by an internal thermostat or one that is...-
by Pookie007I am installing cooling fans for my audio cabinet this weekend and welcome any suggestions on my planned installation.
My audio equipment is housed in built-in cabinets. Currently there is no ventilation so I leave the door open. There is also a shelf 1/2 way up. The plan is to install...-
Channel: Mission Possible DIY
by basementjackI just built an in wall cabinet for my components.
I'm concerned about ventilation - I don't want to bake my components!
It is a simple cabinet with room for 4 components (3 shelves, plus the bottom)
The front is open, the back is currently covered by black fabric....-
by Gordon MooreWell, when cutting the stock fan exhaust plate out of the powersupply (to improve airflow), make sure the power supply is unplugged and FULLY discharged before doing so (Like wait an hour or so). The jarring action of the tin snips must have caused 2 caps (or something inside) to touch. The PS was turned... - Loading...
- No more items.
