Anyone Use A Cabinet Fan Or Cooler
  • greenhorn
    • Feb 2007
    • 204
    Here's the deal. When I first got my Pre-Amp and Amp the Amp didn't go into the cabinet with the Pre-Amp, DVD Player, Cable Box...I had it outside as I didn't think it would fit well.
    Wife really prefered that it would go in the cabinet, so I ditched the VCR, did some re-arranging and in it went. Have been checking to see how warm it's been getting and today it was warmer than I would have liked.
    I looked on line and see there is a few differnt ways to go. Basic draw fan to pull out air, ducted fans, plates with fans to go under or over the component...
    Unfortunatly the cabinet is enclosed for the most part and the wife likes it It's a two door deal with 2 sides, one shelf on each side. Two front door are wooden framed with glass. Top, bottom and sides are solid. Back has 2 slots (one on each side) about 1" wide x 2' high, basically cabling slots.
    Anybody using a basically enclosed cabinet with some type of fan(s) of ventilation scheme?
  • zmanbands
    • 151
    $ 5 fans at Walmart.
    You can hear them up close at low listening volume but not at your listening volume. Have wife choose color. Get 2 of them. Closed cabinet NOT good however. If you can't comfortably have your hand on the amp it's too hot. At least crack the doors. Your component life will probably be diminished. Have wife set aside $ each week for equipment you will need to replace.
    • riceaterslc
      • 205
      haha classic. if you have your wife do this, you sir, have a keeper. for everyone else like me i wish you luck trying to get this to happen. :lol:
      chris
        greenhorn, I have a mains powered fan at the back of my amp's cabinet, and it's very effective. Initially I experimented with a PC cabinet fan but it just wasn't powerful enough. I have drilled a 3-inch hole in the back of my cabinet behind the fan so that the fan draws cool air from outside the cabinet rather than just circulate warm air. I used to have doors on the front of my cabinet. One day I just removed them. I must have picked a good day because my wife never said a word.
        • Russ L
          • 544
          Rotel RKF-100 Custom Rack Fan
          This is rack mountable and contains 3 fans. It has 2 thermal sensors- one internal and one external. I assume the fans are quiet but it may draw air from the front which might not suit your problem. $119 and if you have Rotel it'll match your other gear- has the Rotel badge and all. I think I just sold myself on this unit :lol: -Russ
          Russ
            Yeah, I use different rack fans--an Elan Zfan, and Parasound, also coincidentally named Zfan. Both work great, but like Nigel said, if you can blow air THROUGH the cabinet, it's even better. My current setup has open full-size racks, so I no longer have to worry about enclosed cases.
            • littlesaint
              • 824
              Blower fans are nice. They move a lot of air and are relatively quiet. Usually DC powered though.
              Santino
              • greenhorn
                • Feb 2007
                • 204
                Thanks for all the info, I've come up with a 2 fold resolution. First is the front doors can actually be tee-pee'd i.e., one door has an over lapping flap that I can use against the other so the doors don't actually close all the way and allow for some good ventalation. Second is that I found a fan at a semi local Hi-Fi store that I will alos put in the cabinet. It's wired short to be plugged into a switched device, but neither my Pre-Amp or Amp had an accessory \ switched plug spot... Cable box saved the day.
                • eljr
                  • Aug 2007
                  • 88
                  I have had recomended, PQFan 29db about a $100.00 a pair with guards and power cord. They are very quiet about 30db.
                  What you got back home, lil' sister, to play yer fuzzy warbles on? Pitiful, portable picnic players?
                  Come with uncle & hear all proper! Hear angels trumpets & devils trombones. You are invited!
                  • Steve B
                    RSP 1098 running hot?
                    by Steve B
                    I couldn't find another thread on this topic, but it probably has been covered...
                    I just got a 1098 a couple weeks ago (love it). Mine is in a cabinet that is completely enclosed, but I am using a series of fans to pull the hot air out of the cabinet. I think there is good airflow, and...
                    22 January 2004, 16:02 Thursday
                  • neverwouldof
                    Anyone have JC1's in Entertainment Cabinet? meaning Not in open air..
                    by neverwouldof
                    Ready for some stupidity.... (3) JC1's , (1) A21 , C1 Controller, Denon 5910 DVD/CD. All supposed to fit into a very large and very expensive Entertainment Unit. 11.5 feet wide unit that is 22" deep. I have nowhere to put equipment except inside Ent. Unit. A rack will not fit anywhere close...
                    06 November 2005, 10:26 Sunday
                  • Pookie007
                    Audio Cabinet Cooling
                    by Pookie007
                    I am installing cooling fans for my audio cabinet this weekend and welcome any suggestions on my planned installation.
                    My audio equipment is housed in built-in cabinets. Currently there is no ventilation so I leave the door open. There is also a shelf 1/2 way up. The plan is to install...
                    26 February 2007, 21:51 Monday
                  • cmr15
                    Using 12v trigger to run accessory fans
                    by cmr15
                    I've got a 1067 which runs rather hot, and I'm aware that that's the norm. I'm about to place it in a custom wall unit and need a little info regarding the use of fans and a 12v trigger.
                    What I'd like to do is use 2 accessory computer fans to circulate the air. One would pull in air...
                    14 March 2005, 17:37 Monday
                  • JerryB
                    A3.5 Integrated Heat Slots
                    by JerryB
                    Can anyone with a MF A3.5 integrated tell me it the heat releasing slots on the case are on the top only, bottom only or both top and bottom of the case? My unit has heat releasing slots only on the bottom of the case. I ask this question only because I have seen photos on the internet with the A3.5...
                    05 September 2007, 22:17 Wednesday
