rptv and Sony PS 2
  • soundhound
    • Mar 2004
    • 815
    rptv and Sony PS 2
    I just recieved a Sony PS 2 for my b-day, the kids got me grand theft auto III and vice city (not hard to figure out what drove those gifts...) I have been playing them since last weekend and finally decided to read some of the literature that came with the PS 2. It says DO NOT USE WITH PROJECTION TV. I read thru my Toshiba 46H84 manual last night and could find no warnings pertaining to video games. Any video experts no why Sony puts this warning in their manual? Should I not be running into my Toshiba? Is it simply the burn in the stills will do to the phosphor or is there more to it than that? I am overly cautious about leaving "still" images on the monitor due to what I have read about the damage that can be done. Thanks, Bob
    Twin Moderator Emeritus
    • 16706
    Yes it's basically a warning because of stationary things like life meters etc. on video games that can cause burn-in. If you don't play for 6 hours a day almost everyday you should be OK. However there are no guarantees with phosphor based displays (CRT/Plasma) That said, millions of people play games on there sets with no problems. As long as you don't overdue it you should be fine.
    • Kevin P
      • 10808
      If your set is properly calibrated (that is, contrast is cranked way down for starters), the risk of uneven phosphor wear (aka burn-in) is greatly reduced. As long as you play games in moderation (no 12 hour marathons with one game), and mix with other sources (TV and movies) you should be fine.
      For a worst case scenario for RPTV burn in, go to your nearest arcade or entertainment establishment and check out the games that use RPTV displays. Chances are you'll see severe burn in on those.
